I know, I know, its not PC-DMIS issue but I'm getting a vibration or dragging sound and I wanted to ask, I have a b&s global image what PSI should the regulator at the machine be set to?
My reg. reads 60 psi, not sure what it should be, I had an LK that ran at 90lbs, I am in N Texas and it was 101 deg outside and my lab was up to 73.5 deg yesterday, not sure if that has any bearing on all this. before I came to Texas they had over 30 days in a row over 100 deg, 1980 I think. THANKS for the quick response.
Thomas
Our new Global Image 9128 was installed/setup with the service tech's setting of 80 psi......Upon having issue with startup and low air E-stop the visiting repair tech said it was too high and lowered it to 60psi....go figure....one tech setup the mach at 80 the "repair" set it to 60...hmmm?? I think the real concern would be the balance between the xy air regulated by the gage under the table and the Z axis counterbalance air pressure. This "balance" I was told is necessary to provide proper E-Stop upon a low air condition.
Global Image Active 22.12.10 set at 70ish bar, or 4.6 bar. runs fine at that.
With a Global, the counterbalance for the Z axis is Pneumatic, so if there isn't enough air, you won't be able to set the servo's if there is insufficient wind!!
I am a Mushroom................Kept in the dark and fed on sh*t!!!!!
When I noticed the temperature fluctations you mentioned, I started remembering a condensation issue we had. Check your air lines for water. Last summer we had lots of problems with water in our air lines throughout the building. I think some of it came from the fact that we have lines that run through the hottest areas of the shop, into what some call "the refigeration zone". (CMM lab!) Keep an eye on that.
does any one have info on air pressure faults, having issue keeping things running with out the CMM kicking out due to air pressure....what is the correct...
