Whacky angles and misplaced planes
  • Whacky angles and misplaced planes
    I have a problem that doesn't make any sense.
    I made a program for a part involving angles and different workplanes, and the workplanes are correct. Using the same part, I ran the program automatically after taking all of the hits. The program runs smoothly until it gets to an angled plane. It errors out when it goes to take the hits. The workplane is XPLUS and the tip moves in the XMINUS direction.
    Then when it gets to another plane in the XMINUS direction, the probe moves in the YMINUS direction. I took the hits and re-took the hits 3 or 4 times, even changing the workplanes to see if different ones fit. Nothing seems to work. Does anyone have any ideas?The version(I think) is PCDMIS CAD++3.5 Maintenance Release 2. I'm guessing by code you mean the commands for the hits(I'm somewhat new to this):
    A1 =ALIGNMENT/START,RECALL:STARTUP, LIST= YES
    ALIGNMENT/LEVEL,YMINUS,PLANE1
    ALIGNMENT/ROTATE,XPLUS,TO,LINE5,ABOUT,YMINUS
    ALIGNMENT/TRANS,XAXIS,CIRCLE1
    ALIGNMENT/TRANS,ZAXIS,CIRCLE1
    ALIGNMENT/TRANS,YAXIS,PLANE2
    ALIGNMENT/END
    MOVE/POINT,2.8272,-1.2894,6.1563
    MOVE/POINT,-6.9094,-2.5574,16.4869
    MOVE/POINT,-6.9092,-2.5576,16.4867
    TIP/T1A90B-75, SHANKIJK=-0.9403, -0.3404, -0.0034, ANGLE=89.4366
    MOVE/POINT,-2.7849,-3.5575,9.1333
    MOVE/POINT,-2.5705,-1.146,0.8978
    MOVE/POINT,-0.127,-0.3962,0.2881
    WORKPLANE/XPLUS
    PLANE7 =FEAT/PLANE,RECT
    THEO/1.2669,0.127,-0.0467,0.9389291,0.3441107,-0.0002
    ACTL/1.1637,0.0825,-0.0483,0.9389484,0.3440579,0.0003302
    MEAS/PLANE,4
    HIT/BASIC,1.1446,0.1197,0.325,0.9389291,0.3441107,-0.0002,1.1517,0.115,0.3234,USE THEO = YES
    MOVE/CIRCULAR
    HIT/BASIC,1.1695,0.0516,0.0754,0.9389291,0.3441107,-0.0002,1.1765,0.0473,0.0737,USE THEO = YES
    MOVE/CIRCULAR
    HIT/BASIC,1.1366,0.141,-0.2349,0.9389291,0.3441107,-0.0002,1.1437,0.1373,-0.2364,USE THEO = YES
    MOVE/CIRCULAR
    HIT/BASIC,1.1758,0.0341,-0.3522,0.9389291,0.3441107,-0.0002,1.1828,0.0306,-0.3539,USE THEO = YES
    ENDMEAS/
    I added the alignment I used just in case that was needed. The part has a hole in the middle, planes 1 and 2 are facing the same way, and the part is sitting up facing the YMINUS direction.
    Last edited by operator1; 07-23-2007, 11:02 AM. Reason: Adding more helpful information
    I feel a lot better now that I've lost my mind.
    Global Activ
    PCDMIS CAD ++3.5 MR2
    Take a look at the feature vectors. Sounds like an issue there.
    Can you post version # and some of the code?
      Post some code. If you are checking a PLANE (or any other 3D Feature the Workplane is inconsequential).
      Bill Jarrells
        I've had issues with measured planes taking hits opposite from where I showed it. Your best bet is to F9 the hits and choose the "RELEARN" checkbox. Then run it again and re-teach it. This should always fix it.
          ALIGNMENT/END
          WORKPLANE/XPLUS
          MEAS/PLANE,4
          MOVE/CIRCULAR
          MOVE/CIRCULAR
          MOVE/CIRCULAR
          ENDMEAS/
          When you taught this plane did PC DMIS guess it as a Circle? Just wondering because of the circular moves between the hits. Just a note, but I have had issues with Planes that were 'guessed' as circles and then over-ridden as planes. I am now in the habit of deleting the feature when that happens and try it again. You can always select PLANE before you measure and PC DMIS will not have to guess.
          Might not be your problem here but I have experienced it.
          Bill Jarrells
            Re-teaching it as a plane did work--although it created another plane when I added the hits. Now my concern with that is consistency, but for now it works. I thank you dearly for that advice.
            Now my concern is on the plane set at an angle. How should I try to fix that? Can anyone help me with the angle?
            Global Activ
              What's wrong with the angled plane?
                Everytime it goes to take a hit, it moves too far in. I know it's not the prehit distance because the prehit is set to .115 as opposed to the usual .05 or .04... I think it was guessed as a circle when I first created the plane, and I had to override guess, but would that cause the tip to error out going too far in?
                Global Activ
                  It has to be your circular moves that are in between your hits. Highlight them and delete them. Run it again, I bet that'll fix it.
                    Underspec, you are my new hero! My program works now. That did it. Thank you sooooo much!!!
                    Global Activ
                      Wingman, I thank you also. If it weren't for you, I wouldn't have been able to fully complete the program.
                      Global Activ
                        Many thanks to you as well, Wingman. Your advice helped me with my 2nd plane problem.
                        Global Activ
