Touch speed
  • Touch speed
    I have fairly large tips with extensions. Just wondering what everyone has their touch speed set to. We are at 1%.
    2% here
      I am a member of the 1% club.
      (99% of people give shiite; 1% don't)
        1 to 2 depending on the machine.
        sigpic GDTPS - 0584
          2 or 1 depending on material
          3.7 MR4
            2%
            Was
            Pc-dmis 3.5 MR1 B & S 2009 MR1
            Now
            2010 MR3
              2%
                1 %
                  Depends on the styli, sensor conf., including if any ext. module..
                  "when in doubt, check it out"
                    I am at 1.2%.
                    B. Jacobs
                    B&S Global 12.15.10
                    2014.1
                      I try to touch as fast as possible - don't want to waste a bunch of time if she's not into it........
                        1.2% TO 2% depending on config etc....
                          You're gonna get mis-hits and probe crashes that way
                            .75 here... I have always tested the touch speed of tips against a xxx ring to determine the best speed for the set up. .75 has almost always tested out to be the most accurate for the speed.
                            Badges..... We don't need no stinkin badges.
                              1.2% for the Leitz Probing system
