How does pc-dmis calculate coaxiality? I got a problem with this holes as you see cyl2 to cly3 the position of the two cylinder only has a difference of .0003 since cyl2 Y= -.0001 and cyl3 Y= +.0002. The X is the same .0001. How does it makes this .0015 coax ? Same issue with the other two hole with cyl4 to cyl5. See screen shoot of the measured holes. The circles are measured so I can see if the holes are tapering and also used them to create the cylinders.
Edit.:Attachment looks too small to read. Not sure why .
