Running a b&S Global with a TP200 on a renishaw PH10M
We have 3 standard force modules and as I was working on a program with a 2mm Ruby tip and had a one of the module is hanging up when you push on it.
The other modules drop up and down easily
tried a lil alcohol in case any crud was in there but did not make it any better
switch tip to another module and calibrated to get going--so up and running
Question
does anyone no if there are springs inside the modules?
if yes can we replace them
and does anyone know if they rebuild teh modules and is it worth it or just replace with new/
Thanks
Question
Thanks
