When I create an alignment in 3.5 PCDMIS, I have it lock down so that the xyz icon is not rotating in any positions. As I continue to program it seems like my alighments get off track and moves the xyz icon to another place. Even tho the aligments has not been touch again from the original alignment. Any ideas would help.
alignments keep moving
When you say moving, do you mean your XYZ zero is actually changing? Or is the trihedron moving in your part? If you've got scale to fit on you may see the latter.
One thing I do to "verify" my alignment is manually move the tip as close to 0,0,0 as possible. Look at the readout and verify that your alignment is correct.
Another idea. If you are using a line in your manual alignment, you need to make sure the hits are always taken in the same order. (ie. xminus to xplus) I've forgotten what I did the day before and ran my manual alignment incorrectly. WHAT A MESS! I was to stubborn to look at the vector of the line (DUH!) and now add COMMENT/operator to any manual alignments I use.
Hope this helps.When in doubt, post code. A second set of eyes might see something you missed.
by jamshedI have been reading up on the forum to get my information. Most important is never alig without rotate.I rotate in my Rough alignment, do I have to rotate...
01-22-2017, 06:25 PM -
by sbuesoI have try a few things with this program and still not sure how to fit it.
I've been away from CMM Programming for about 4 years now, getting back...-
03-15-2017, 07:14 PM -
by MJA75I have a large cross shaped tubular part laid down on the plate at a 45° to get into all 4 ends. Through most of the programming, the controller moved...
11-12-2008, 05:59 PM -
by bosnjodyO.K. This is probably the most basic (I would think) thing to do.
I have CAD++ Ver 3.5 MR1. I wrote a program to inspect a part.
Worked...-
03-09-2011, 04:00 PM -
by FMX554Ok so why does my xyz change from manual to dcc when i use the same alignment
01-25-2010, 04:04 PM -
