Does anyone know how to add the header and footer as in versions prior to 3.7 into version 4.2. Attached is a sample of the current report? The information highlighted in yellow is what we are looking to add.
Adding report header and footer information in 4.2
You need to edit the header label. I changed mine based on information I got from the class. Before you do anything, backup your reports folder to a safe place. One oops and you're done. Open windows explorer and change the contents of the reporting folder from read only. Start at File, Reporting, Edit and Label Template. Look for header and open it. Someone in here has some docs on it. Buehler, Buehler.sigpic GDTPS - 0584
Go intor your report editor and edit the template you want to change. Make a backup of course. Right click the textoutput object (body with dimensions) and turn OFF header. Resize the body down a bit and insert another textoutput object above that. Right click that object and TURN OFF EVERYTHING except the Header. That will remove the Header.LBL and insert a v3.7 lookalike header.I used to be high on life but I built up a tolerance.
by DHARTNESS55How do we not show the PCDMIS header on Reports. Engineers have to remove them before Uploading to Customers site. Just want to take it off compl...
10-28-2020, 02:01 PM -
by GmotasHello,
Need some help! Have anyone edit the header (see pic).
Already changed the logo......-
11-30-2018, 11:18 AM -
I'm trying to create a header i can edit in word.
4.3's headers turn to pics when saved as an rtf. file.
so,I moved the text box for the...-
04-03-2009, 12:17 PM -
by oddamJust started using 2015 mr1, was using 2014 mr1. I want to remove the default pcdmis report header and put my company header on the report. I searched...
07-06-2016, 04:54 PM -
by deasyseProblem I'm having is with the report header. I don't use marked sets in my programs, I mark everything. I build a menu structure and use labels to branch...
06-01-2007, 07:05 PM -
