I am currently using MR2 and on the last hit of calibration the disk slams into the qual sphere. I was told that MR3 has fixed this. Anyone know if this is true? Also, has anyone had many new problems with MR3?
Disk probe calibration in 3.7 MR3
Originally posted by Nevets View PostI am currently using MR2 and on the last hit of calibration the disk slams into the qual sphere. I was told that MR3 has fixed this. Anyone know if this is true? Also, has anyone had many new problems with MR3?
disk stylus with analog probe
This is a problem also for ver 4.2, and 4.1. However the calibration is going through the entire procedure, measurement with disk stylus is giving strange results. The only calibration method is 5 points by two levels. If you try to increase the number of the measuring points probe will hit the calibration sphere.
I have made a scanning test on a ring gauge with different probes (ball and disk) Roundness with ball stylus was 0.005mm with disk probe was 0.025mm ~ 5 times bigger. Strange is that measurement point by point with disk stylus is giving similar results 0.005mm.
Waiting for WILCOX to solve the problem.
Regards,
Zsolt
Does anybody know how to calibrate a disk in PCDMIS 2010 MR2.
Im getting out of calibration disk by 2 mm or so, because when I send to calibrate...-
11-09-2010, 03:22 PM -
Hello all!
I am using PC DMIS 3.7 MR2 with SP25. I would like to calibrate a disk probe D45 and 1.5 mm thickness.
Seems...-
01-15-2007, 09:20 AM -
by programmerI am PCDMIS 4.3 and having problem trying to calibrate a disk probe. any help???
08-04-2009, 01:10 PM -
by bpenningsDoes anyone have a documented procedure for calibrating disk probes? The PCDMIS procedure does not work for me for some reason. It is 18mm in dia. and...
04-22-2008, 06:22 PM -
by David WedelCan anyone tell me the best way to calibrate a disk probe
Man+DCC, DCC+DCC and levels and angles set at including number of ...-
03-04-2010, 10:34 AM -
