I have a customer that sent me a program in 3.2. I opened it ran it offline and did some editing (with the customer's approval) and would like to send it back to him but I can only save back to V3.5. Can I copy the code into a Word or text document, send it back to him and then have him copy and paste the new code into his original program?
3.7mr3 to 3.2 programs
Originally posted by dwade View PostI have a customer that sent me a program in 3.2. I opened it ran it offline and did some editing (with the customer's approval) and would like to send it back to him but I can only save back to V3.5. Can I copy the code into a Word or text document, send it back to him and then have him copy and paste the new code into his original program?sigpic
I tried that once. It didn't work.
You should be able to save back farther than that. If you do a 'save-as' down at the bottom of the window will be a drop down. In the box will be "PC-DMIS part program" If you drop it down, you should be able to click the down arrow and get 3.2
I'm using v4.1. Farthest back I can save is v3.201. I've never tried copying the code onto a text file and pasting it back into a program. Would be interesting to find out.I used to be high on life but I built up a tolerance.
Originally posted by Underspec View PostI've never tried copying the code onto a text file and pasting it back into a program. Would be interesting to find out.
Originally posted by Goodluck View PostIt doesn't work, I've tried it. If it did, you could program "offline" if you could remember the text and where to put spaces and commas and such.I used to be high on life but I built up a tolerance.
Originally posted by RussL View PostWoud exporting to DMIS in 3.5
and importing from DMIS in 3.2 work
Just a thought.I used to be high on life but I built up a tolerance.
Well I need to pull my head out of my butt. When I opened the "save as" and opened the pull down all I ever saw was the 3.6 and 3.5. Didn't think of scrolling with the arrowto see if there was anything below the 3.5.
Thanks for the enlightenment
DuaneXcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
by SchlagI need to send a program to one of our customers. We are running 2011 MR1 and they are still on 3.2. Im sure the chances of this working are slim to...
06-01-2012, 12:35 PM -
by dwadeGot a supplier that is having problems with programs that have been saved back from 3.7MR3 to V3.2063. I have done this several times for them and have...
08-11-2008, 10:51 AM -
by C-cmmI have a bit of trouble bringing in customer programs and running them smoothly. 1. It seems like the cad is never rendered correctly and I can't change...
01-13-2009, 05:59 PM -
by TestedI'm up at another shop that has V3.2063. I need the guy at my shop to convert a 4.2 version to the 3.2063 and send it to me.
but I can't remember...-
12-23-2008, 01:14 PM -
by fixin2Currently running 4.2mr1. I started writing a program last night. I constantly hit ctrl+S to save after each feature I create. So last night before logging...
04-01-2008, 07:28 PM -
