Max-Min points on scan
  • Max-Min points on scan
    Hi,
    how can i find the Max and Min points on scan along X or Y or Z ?
    I need these values based on the actual reference sistem
    Thanks
    Originally posted by usrpcdmis View Post
    Hi,
    Thanks
    When you dimension out the scan (profile?), set the "textual" mode to yes/on whatever name it is. That will give you max and min values.
      Thanks but i need some suggestions how create a procedure to find these values automatically.
        Here's a sample of how I have extracted the High Point from a scan. I've included comments in the sample
        Hope this Helps
        COMMENT/DOC,NO,=========================================== =========================
        ,SCN6 is used to extract the high point of the part and use this
        ,in feature F1, for future dimensions
        SCN6 =FEAT/SCAN,LINEAROPEN,SHOWHITS=NO,SHOWALLPARAMS=NO
        MEAS/SCAN
        BASICSCAN/LINE,SHOWHITS=YES,SHOWALLPARAMS=NO
        HIT/VECTOR,2474.648,215,94.732,0.9313237,0,-0.3641926,2477.912,214.996,93.455,T=3.505
        HIT/VECTOR,2475.485,215,97.088,0.9522529,0,-0.3053105,2478.794,214.998,96.026,T=3.475
        HIT/VECTOR,2476.174,215,99.492,0.9694731,0,-0.2451977,2479.517,214.997,98.649,T=3.448
        HIT/VECTOR,2476.711,215,101.935,0.9829031,0,-0.1841238,2480.104,214.997,101.304,T=3.451
        HIT/VECTOR,2477.094,215,104.407,0.9924896,0,-0.1223288,2480.478,215.001,103.992,T=3.409
        HIT/VECTOR,2477.323,215,106.898,0.9981948,0,-0.0600588,2480.699,214.999,106.691,T=3.382
        HIT/VECTOR,2477.407,215,109.396,0.9997688,0,-0.0215038,2480.82,214.999,109.323,T=3.413
        HIT/VECTOR,2477.453,215,111.895,0.9998836,0,-0.0152564,2480.941,214.998,111.843,T=3.488
        HIT/VECTOR,2477.484,215,114.395,0.9999594,0,-0.009009,2480.988,214.999,114.364,T=3.504
        HIT/VECTOR,2477.498,215,116.895,0.9999962,0,-0.0027611,2480.829,214.997,116.885,T=3.331
        HIT/VECTOR,2477.497,215,119.395,0.9999892,0,0.0046506, 2480.83,214.997,119.411,T=3.333
        HIT/VECTOR,2477.475,215,121.895,0.9999157,0,0.0129837, 2480.779,215.001,121.942,T=3.305
        HIT/VECTOR,2477.432,215,124.395,0.9997728,0,0.0213159, 2480.687,215.006,124.463,T=3.256
        HIT/VECTOR,2477.368,215,126.894,0.9995604,0,0.0296466, 2480.56,215.002,126.988,T=3.193
        HIT/VECTOR,2477.284,215,129.393,0.9992787,0,0.0379753, 2480.424,215.001,129.513,T=3.142
        HIT/VECTOR,2477.178,215,131.891,0.9989274,0,0.046303,2 480.256,215.001,132.032,T=3.081
        HIT/VECTOR,2477.052,215,134.389,0.9985067,0,0.0546295, 2480.047,214.999,134.552,T=2.999
        HIT/VECTOR,2476.905,215,136.886,0.9980165,0,0.0629525, 2479.813,215,137.068,T=2.913
        HIT/VECTOR,2476.737,215,139.381,0.9974571,0,0.0712698, 2479.62,215,139.585,T=2.89
        HIT/VECTOR,2476.549,215,141.874,0.9968285,0,0.0795801, 2479.354,214.999,142.098,T=2.814
        HIT/VECTOR,2476.334,215,144.366,0.9949984,0,0.0998912, 2479.055,214.998,144.637,T=2.734
        HIT/VECTOR,2476.032,215,146.849,0.9899695,0,0.1412815, 2478.63,215,147.219,T=2.625
        HIT/VECTOR,2475.627,215,149.317,0.9832229,0,0.1824084, 2478.107,214.999,149.777,T=2.522
        HIT/VECTOR,2475.12,215,151.767,0.9747645,0,0.2232359,2 477.477,214.999,152.308,T=2.419
        HIT/VECTOR,2474.511,215,154.192,0.9646161,0,0.2636584, 2476.757,215.002,154.803,T=2.328
        HIT/VECTOR,2473.801,215,156.59,0.9527882,0,0.3036357,2 475.938,215.001,157.27,T=2.242
        HIT/VECTOR,2472.992,215,158.957,0.9393094,0,0.3430712, 2475.011,214.999,159.691,T=2.148
        HIT/VECTOR,2472.527,215,160.188,0.9315577,0,0.3635935, 2474.483,214.999,160.948,T=2.099
        ENDSCAN
        ENDMEAS/
        FORMAT/TEXT,OPTIONS, ,HEADINGS,SYMBOLS, ;NOM,TOL,MEAS,MAXMIN,DEV,OUTTOL,
        DIM PROF4= PROFILE OF LINE OF SET SCN6 FORMANDLOCATION UNITS=MM ,$
        GRAPH=ON TEXT=OFF MULT=10.00 OUTPUT=BOTH
        AX NOMINAL +TOL -TOL MEAS MAX MIN DEV OUTTOL
        M 0.000 3.000 3.000 3.505 3.505 2.099 3.505 0.505 -------->
        ANALYSISVIEW/PROF4,,
        COMMENT/DOC,NO,NHITS, Counts the number of hits in scan, which we use to make sure
        we count all hitswe count all hits
        ASSIGN/NHITS = SCN6.NUMHITS
        COMMENT/DOC,NO,C is the counter to loop through, and start at 1
        ASSIGN/C = 1
        COMMENT/DOC,NO,MAXVAL is going to be used to store the max height
        ASSIGN/MAXVAL = 0
        DO/
        COMMENT/DOC,NO,MYVAL is a temporary value to store the hit at that count
        ASSIGN/MYVAL = SCN6.HIT[C].X
        COMMENT/DOC,NO,If myval is greater than maxval we update maxval for future comparisons
        ,If this is the case we store the hit number in assignment hitn
        IF/MYVAL>MAXVAL
        ASSIGN/MAXVAL = MYVAL
        ASSIGN/HITN = C
        END_IF/
        ASSIGN/C = C+1
        UNTIL/C==NHITS
        COMMENT/OPER,NO,"Max Value Is"+MAXVAL+"AtPoint"+HITN
        COMMENT/DOC,NO,Everything above finds the maximum hit within the scan.
        ,Below we create a generic point using that hit value
        F1 =GENERIC/POINT,DEPENDENT,RECT,$
        NOM/XYZ,SCN6.HIT[HITN].TX,SCN6.HIT[HITN].TY,SCN6.HIT[HITN].TZ,$
        MEAS/XYZ,SCN6.HIT[HITN].X,SCN6.HIT[HITN].Y,SCN6.HIT[HITN].Z,$
        NOM/IJK,0,0,1,$
        MEAS/IJK,0,0,1
        DIM LOC54= LOCATION OF POINT F1 UNITS=MM ,$
        X 2474.648 2.000 2.000 2480.987 2480.987 2480.987 6.339 4.339 -------->
        Y 215.000 0.500 0.500 214.997 214.997 214.997 -0.003 0.000 ----#----
        Z 94.732 2.000 2.000 114.364 114.364 114.364 19.632 17.632 -------->
        END OF DIMENSION LOC54
        It goes "dink" so it must be workin'
        Bollocks
          PLN2 =FEAT/PLANE,CARTESIAN,TRIANGLE
          THEO/<-88.901,1.113,11.915>,<-0.0695989,-0.0318903,0.9970652>
          ACTL/<-88.861,1.106,11.912>,<-0.0695988,-0.0319105,0.9970646>
          MEAS/PLANE,5
          MOVE/CLEARPLANE
          HIT/BASIC,NORMAL,<-85.23,-23.661,12.458>,<-0.0695989,-0.0318903,0.9970652>,<-85.194,-23.574,12.454>,USE THEO = YES
          HIT/BASIC,NORMAL,<-63.505,-1.591,14.068>,<-0.0695989,-0.0318903,0.9970652>,<-63.544,-1.617,14.062>,USE THEO = YES
          HIT/BASIC,NORMAL,<-85.384,24.811,13.166>,<-0.0695989,-0.0318903,0.9970652>,<-85.321,24.738,13.159>,USE THEO = YES
          HIT/BASIC,NORMAL,<-113.757,7.533,12.242>,<-0.0695989,-0.0318903,0.9970652>,<-113.682,7.514,12.241>,USE THEO = YES
          HIT/BASIC,NORMAL,<-96.628,-1.527,7.642>,<-0.0695989,-0.0318903,0.9970652>,<-96.564,-1.531,7.642>,USE THEO = YES
          ENDMEAS/
          ASSIGN/MAXZ = MAX(PLN2.HIT[1..PLN2.NUMHITS].Z)
          ASSIGN/MAXZPT = MAXINDEX(PLN2.HIT[1..PLN2.NUMHITS].Z)
          ASSIGN/MINZ = MIN(PLN2.HIT[1..PLN2.NUMHITS].Z)
          ASSIGN/MINZPT = MININDEX(PLN2.HIT[1..PLN2.NUMHITS].Z)
          COMMENT/OPER,NO,MAXZ
          ,MAXZPT
          ,MINZ
          ,MINZPT
          Something like this?
            Hope this Helps
            MEAS/SCAN
            ENDSCAN
            ENDMEAS/
            ASSIGN/C = 1
            ASSIGN/MAXVAL = 0
            DO/
            IF/MYVAL>MAXVAL
            ASSIGN/HITN = C
            END_IF/
            ASSIGN/C = C+1
            UNTIL/C==NHITS
            NOM/IJK,0,0,1,$
            MEAS/IJK,0,0,1
            Thanks
              MEAS/PLANE,5
              MOVE/CLEARPLANE
              ENDMEAS/
              ,MAXZPT
              ,MINZ
              ,MINZPT
              Thanks
                When creating the profile, choose textual analysis?
                   FORMAT/TEXT,OPTIONS,ID,HEADINGS,SYMBOLS,SD;MEAS,NOM,TOL,DEV,OUTTOL,MAXMIN,
                  DIM LOC100= PROFILE OF SURFACE OF SET SET1    FORMANDLOCATION  SD=0.000  UNITS=MM ,$
                  GRAPH=OFF  TEXT=OFF  MULT=40.00  OUTPUT=NONE
                  AX       MEAS    NOMINAL       +TOL       -TOL        DEV     OUTTOL        MAX        MIN
                  M       0.000      0.000      0.750      0.750      0.000      0.000      0.000      0.000 --------|---------
                              ASSIGN/PROF1MAX = LOC100.MAX
                              ASSIGN/PROF1MIN = LOC100.MIN
                  PROF_SET1MAX=GENERIC/POINT,DEPENDENT,CARTESIAN,$
                              NOM/XYZ,<PROF1MAX,0,0>,$
                              MEAS/XYZ,<PROF1MAX,817.363,-647.605>,$
                              NOM/IJK,<0,0,1>,$
                              MEAS/IJK,<0,0,1>
                  PROF_SET1MIN=GENERIC/POINT,DEPENDENT,CARTESIAN,$
                              NOM/XYZ,<PROF1MIN,-545.904,0>,$
                              MEAS/XYZ,<PROF1MIN,271.465,-646.71>,$
                              NOM/IJK,<0,0,1>,$
                              MEAS/IJK,<0,0,1>
                              ANALYSISVIEW/LOC100,,
                              COMMENT/REPT,LOC101, MAX Profile to inside radius around Datum C
                                          ,at 69.6mm from Datum C pocket
                              FORMAT/TEXT,OPTIONS,ID,HEADINGS,SYMBOLS,SD;MEAS,NOM,TOL,DEV,OUTTOL, ,
                  DIM LOC101= LOCATION OF POINT PROF_SET1MAX  SD=0.000  UNITS=MM ,$
                  GRAPH=OFF  TEXT=OFF  MULT=40.00  OUTPUT=BOTH
                  X       0.000      0.000      0.750      0.750      0.000      0.000 --------#---------
                  END OF DIMENSION LOC101
                              COMMENT/REPT,LOC102, MIN Profile to inside radius around Datum C
                  DIM LOC102= LOCATION OF POINT PROF_SET1MIN  SD=0.000  UNITS=MM ,$
                  END OF DIMENSION LOC102
                  This will give you the MAX and MIN deviation of a scan when using the profile of a surface button. If you only want the MAX part you can delete the MIN.
                  sigpic GDTPS - 0584
                    Under Parameter Setting
                    You Can Turn On Maxmin On The Dimension Output Format.\
                    And It Will Display Max Min
                    FORMAT/TEXT,OPTIONS, ,HEADINGS,SYMBOLS,SD;NOM,TOL,MEAS,DEV,MAXMIN, ,
                    DIM PROF1= PROFILE OF SURFACE OF SET SCN1 FORMANDLOCATION SD=0.0006 UNITS=IN ,$
                    AX NOMINAL +TOL -TOL MEAS DEV MAX MIN
                    M 0.0000 0.0025 0.0025 0.0019 0.0019 0.0012 -0.0008 ------#--
                    Global Image 7107 4.2 MR1
                    Global Advantage 575 4.2 MR1
                    Mitutoyo FN1106 4.2 MR1 with STI
                      Good answer. Nobody wants to do anything easy these days. I should have thought of that.
                        For all you 4heads. Right click on the dim in the report window>edit>maxmin. This can be applied to one or all dims by checking the appropriate button in 'Apply Changes To' box
                        sigpic 1.61803399Δ
                        • drako28
                          High Point Extraction ?
                          by drako28
                          I'm trying to find the high point of this scan. I'm using 4.1. Is there something I'm missing? I am only getting the first number out of the scan....
                          11-30-2006, 09:56 AM
                        • dph51
                          T-VALUES from a scan
                          by dph51
                          t-valuesMany have asked for a solution of finding the MAX and/or MIN T-VALUES of a scan.
                          Perhaps this has been solved before, but I submit this...
                          10-08-2010, 11:06 AM
                        • pcmac
                          textual analysis
                          by pcmac
                          Is there a way to output the hit points in textual analysis thru Datapage or the pcdmis-excel dump? I can get them to show up in the rtf but a customer...
                          01-18-2007, 08:45 AM
                        • Underspec
                          Printing Variables!
                          by Underspec
                          I need to do some calculations and print them out from variables as dimensions or to the report. Never really messed with variables so any help will be...
                          08-09-2006, 01:51 PM
                        • #2#
                          Losing Alignment on Angle Change?
                          by #2#
                          Alright, here is my code. The first bit here is with A0B0. Just before the last move point it changes to A90B180.
                           DATUM_B    =AUTO/CYLINDER,SHOWALLPARAMS
                          06-07-2007, 04:34 PM
