MMC on a slot
  • rebeldude
    u2
  • rangerboat72
    started a topic MMC on a slot
    MMC on a slot
    I hope everyone has a GREAT WEEKEND !
    Talk to you Tuesday . . .
  • gordon
    MMC on Slot
    by gordon
    I have a square slot with a TP call out using MMC. The way the slot is called out MMC is granted from the slot length.
    When I dimension the TP,...
    12-19-2008, 10:05 AM
  • Adam Olson
    Help with slot.
    by Adam Olson
    I have a slot or pocket whatever you want to call it which is datum -d-. My problem is that the slot is tapered (will attach a pic and print) and it does...
    09-04-2008, 10:36 AM
  • NBO CMM
    Slot as datums
    by NBO CMM
    I am having trouble with something, I need to know if you can use a single square slot as both the secondary and tertiary datums and if so how would you...
    01-20-2022, 12:47 PM
  • JCollins
    Square Slot MMC Calculation
    by JCollins
    My Question is: Is the Demon calculating my MMC correctly
    Code:
    DIM DIM 8= TRUE POSITION OF SLOT SLT1  UNITS=MM ,$
    GRAPH=OFF  TEXT=OFF
    11-21-2007, 10:30 AM
  • Mike_B
    BOUNDARY on a slot, to A|B|C
    by Mike_B
    I referenced how to calculate the "BOUNDARY"
    I even made sense of why it applies. But how do I "apply" it to my dimensioning?...
    08-18-2015, 10:31 AM
