construction of a circle from vector points
I cannot construct a circle from vector points. Why is that? I used polar mode to easily even space the points and there is some problem with that. The diameter is close but the form is incorrect by 2.5 or 3 millimeters
sigpicRAH
B&S GI 10-7-10
PH10MQ-SP600M
3.7 MR3Tags: None
Hi,
Is there any way to combine two sectors in one circle ? I'm a bit lost there..
Thanks !-
03-11-2014, 02:25 PM -
by ClintThis is my first time posting and I appreciate any help you can give me.
When I construct a circle out of points that have been created...-
04-22-2010, 05:58 PM -
by DeWain HodgeI have a part with a groove diameter that is interupted by two pockets 180° apart so I can only measure about 100° on each side of the pocket. What...
03-12-2008, 10:21 AM -
by 1CMM4MEI Just don't get it.
I am manually programming this part. I took 6 points on a radius. I labeled them as points only. Then I chose to contruct...
01-16-2008, 08:22 PM -
by Virgil UKGood morning.
I have a program with approximately 6,000 move points in. I was wondering if someone VB GURU out there??? could change these...-
09-08-2006, 07:03 AM -
