For some reason the results are way off if I use this min-cirsc on OD's. I program off line with models useing 4.1. The max-insc for ID's seems to work fine. Should I use something besides nominals in the misc. box in auto feature.
min-cirsc on OD's
I brought a CAD model in and checked some nominals to make sure the origin was where I wanted it. After doing my alignments, I like to take some test...
Channel: PC-DMIS Portable
05-17-2013, 09:56 AM -
by sscottIs there a way to disable find nominals for part of a program. I have a poorly drawn CAD model (when I switch from wire frame to solid, the surface covers...
09-07-2011, 11:47 AM -
by John KuglerIf I am measuring with CAD and I do NOT have this on, are the results screwed? I measured the same part with it on and with it off, different results....
01-11-2008, 10:42 AM -
by MrCommentI have a program I've spent the past few days working on, and I'm using CAD and decided to run the program thru offline to see if my Theo values all seemed...
01-04-2007, 01:48 PM -
by TigerSharkhello
I already made a program, CAD designer asked me to update my CAD with a new CAD ( fortunately both CADs located in same XYZ space...-
06-04-2008, 01:03 PM -
