Problem When I changed from 3.7mr2 to 3.7mr3 The move speed changed. (The actual speed that is ) Ex 20% of max speed which is 500 in mr2 is slower than 20% of 500 in mr3. When I go into Edit>prefernces>machine interface set up>params and change the max speed to a lower value the machine does not slow down in existing progs. When I create a new program the values seem to go into affect.
Move Speed
Originally posted by AJHVW93 View PostProblem When I changed from 3.7mr2 to 3.7mr3 The move speed changed. (The actual speed that is ) Ex 20% of max speed which is 500 in mr2 is slower than 20% of 500 in mr3. When I go into Edit>prefernces>machine interface set up>params and change the max speed to a lower value the machine does not slow down in existing progs. When I create a new program the values seem to go into affect.
try deleting the old one and add a new "Edit>prefernces>machine interface set up>params and change the max speed"? a row or two from the originalsigpicSummer Time. Gotta Love it!
Not sure if you did this already but I would open your existing programs and check the speed settings from within that program to see if it changes.I used to be high on life but I built up a tolerance.
Originally posted by AJHVW93 View PostProblem When I changed from 3.7mr2 to 3.7mr3 The move speed changed. (The actual speed that is ) Ex 20% of max speed which is 500 in mr2 is slower than 20% of 500 in mr3. When I go into Edit>prefernces>machine interface set up>params and change the max speed to a lower value the machine does not slow down in existing progs. When I create a new program the values seem to go into affect.Bill Jarrells
Originally posted by Wingman View Post3.73 does not play as well with 3.72 as their names might suggest. However, I have been running a lot of 3.72 programs in 3.73 and I have not had this particular problem The speeds match. Are sure SURE your MAX Speed is the same in both versions? My max speed is set to 254mm / secsigpic
Originally posted by bw_bob View PostCan you not just go to parameters in beginning of program & change move speeds ???sigpic
Originally posted by AJHVW93 View Postyes I can change the move speed to a different percentage and slow it down or speed it up . (I can get the desired speeds) its just that now 20 percent runs like 80 percent thanks
That's like a free turbo charger!I used to be high on life but I built up a tolerance.
Definitley sounds like your MAX Speed is different in the settings editor.Bill Jarrells
Originally posted by Wingman View PostBut 100% is the same speed?
Definitley sounds like your MAX Speed is different in the settings editor.sigpic
Originally posted by AJHVW93 View PostYeah, I mentioned that to tech support and I was told that Edit.prefs.mach interface set up. params was a short cut to the settings editor . I looked in the settings editor and could not find it. I believed what he was saying because open gl settings was listed as well and I no that is in the Settings EditorBill Jarrells
by TommyArrowUm... I have spent 15 minutes trying to find this answer on the forums... It seems like a stupid question but.....
In my f5 settings, the...-
12-06-2013, 11:07 AM -
by ADAM WALLACEI have a program running at 75 percent move speed. I need to slow the move speed down from the 75 because of false triggers moving in the z axis of the...
10-24-2013, 11:23 AM -
by Jonde1Is there a way of changing the default speed on our machine? We have just upgraded to Pc-dmis cad++ 2014 and realise that the machine moves a lot slower...
03-06-2015, 02:22 AM -
by ewadoraHi All
I use PC-DMIS CAD++ 2019 R1 on B&S 5.7.5, its absolute speed is 700 (this is what I see when I open F5 ). Most of our programs run with...-
10-29-2019, 03:14 PM -
!Yet another newbie question!
We just updated to v.4.2. Since that time my machine has been moving much slower than it was. Is there a speed setting...-
10-02-2007, 04:49 PM -
