I know this is been ask before when measuring a circle the postion is always good the diameters is always showing small. So is the any correct setting in the misc. box under the advance tab in a auto feature to check a circle are is this a common thing. Any help are info would help me shutup the operators.
Diameters
Diameters
I know this is been ask before when measuring a circle the postion is always good the diameters is always showing small. So is the any correct setting in the misc. box under the advance tab in a auto feature to check a circle are is this a common thing. Any help are info would help me shutup the operators.sigpicTags: None
What calculation are you using for the diameter? Diameters are set to calculate to least squares by default.I used to be high on life but I built up a tolerance.
I had a disagreement with my boss over diameters a couple of months ago and it got settled by running an R&R I ran on a XX set ring. Ring was 0.5" and using the bore to level the part then measuring the ID with 5 points using LSQ. Out of the 15 times I measured the ID the CMM showed a MAX deviation of 30 millionths and a MIN deviation of 50 millionths.
Maybe I was lucky that time. I really don't trust CMMs much for tight tolerance holes but that kept him from saying the CMM can't measure diameters accurately.Xcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
Originally posted by dwade View PostI had a disagreement with my boss over diameters a couple of months ago and it got settled by running an R&R I ran on a XX set ring. Ring was 0.5" and using the bore to level the part then measuring the ID with 5 points using LSQ. Out of the 15 times I measured the ID the CMM showed a MAX deviation of 30 millionths and a MIN deviation of 50 millionths.
Dwade How close was your results to the .500xx rings calibrated size.
I have found that I can't trust the reported size of dia's, On my xcel cmm with a tp200. But on my Global with a sp600 I can.
both will repeat with about 50 millinoths or less variation, but the xcel is not accurate on the acutal size. it will be off .0003/.0005 on dia'sTime for the Trolls to leave.
Originally posted by William Johnson View PostDwade How close was your results to the .500xx rings calibrated size.
both will repeat with about 50 millinoths or less variation, but the xcel is not accurate on the acutal size. it will be off .0003/.0005 on dia'sBill Jarrells
Originally posted by AuRules View PostI know this is been ask before when measuring a circle the postion is always good the diameters is always showing small. So is the any correct setting in the misc. box under the advance tab in a auto feature to check a circle are is this a common thing. Any help are info would help me shutup the operators.B & S XCEL 7-10-7
Sharpe32 Controller
PH10MQ & ACR1 Toolchanger
TP20 & TP2 Probes
Pcdmis CAD++ 3.7mr3, 4.3mr1, 2009mr1, 2010mr1
Datapage RT 3.33
What size tip and what dia. are you measuring. I have found the smaller the tip usually the better the dia. results for any size dia. Also, taking care to ensure that the circle used to report dia. is measured 'square' helps a lot.
Tip size can be an issue. I was told to use the smallest diameter you feel comfortable using to reduce cosine error. If you use find center or remeasure you should not get any cosine error from the probe.
MAX deviation of 30 millionths FROM NOM and a MIN deviation of 50 millionths FROM NOM.
I also use TP20 on all of out Pfx's and swap out my styli about 4-5 months whether they need it or not.Xcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
Goodluck My xcel is a 12-20-10 which is fairly big. I also use alot of bigger probes up to 8mm in dia. most of the time it is 100mm long by 6mm dia ruby, with carbon fiber stems. On standard force modules.
Wingman my sphere is calibrated and defined correctly. I have also have used the same one between machines to verify. I also thought that the one that came with the xcel was off but it is not.Time for the Trolls to leave.
Originally posted by William Johnson View PostGoodluck My xcel is a 12-20-10 which is fairly big. I also use alot of bigger probes up to 8mm in dia. most of the time it is 100mm long by 6mm dia ruby, with carbon fiber stems. On standard force modules.
Wingman my sphere is calibrated and defined correctly. I have also have used the same one between machines to verify. I also thought that the one that came with the xcel was off but it is not.Bill Jarrells
What you have to remember about dmis & auto circles is this
Max insc is for ID & that dia represents the largest diameter that will fit inside the ID
min circsc is for OD & that represents the smallest circle that would fit over the stud
Least square is just the average of all points.
None measures the diameter itself....my .02sigpic.....Its called golf because all the other 4 letter words were taken
by bowhunter309I looking for a little help understanding what I'm doing wrong. I am trying to measure the diameter of a bore manually. Whenever I measure it, whether...
07-12-2019, 04:08 PM -
by george frickWe have always reported circle measurement using the least square evaluation. I was wondering if anyone uses the max inscribed or minimum circumscribed...
09-07-2008, 02:12 PM -
Got something funny going on with my diameter measurements. I was wondering if someone could give me some insight. I am measuring a part thats outer diameter...
11-06-2014, 11:41 AM -
by mhwoodliefThe CMM consistently shows the diameter of one of our reamed holes too big. The tolerance is tight on the hole (Max 3.1498 Min 3.1489). We've verified...
10-15-2008, 10:17 AM -
by djohnsonAlright so I'm very new to the whole CMM thing. I'm currently trying to measure the inner shell of a cup that is to be welded inside of an outer shell...
02-04-2016, 04:13 PM -
