Anybody see Alignments go blank?
  • Anybody see Alignments go blank?
    I using 4.1 on this machine & I have a program i wrote last week from a solid model.....I use an iterative alignment which i am fairly confident is pretty solid....The program has been running for 9 days 24/7 and today whatyaknow CRASH!!. I open the program to see wtf is goin on here & inside the iterative alignment the features to level,rotate & origin are all missing also where you can identify a label for start & error i had labels identified now have a feature name????? Weirdest thing I have seen...
    Also i just found out that the sister program which is just a mirrored program has done the same thing..Any clues to why the features have disappeared from the align?? I have not edited or touched these programs for 9 days!
    I am currently getting wasted!
    I don't think things just disapear. Interrogate everyone else who uses the machine. I'm sure someone did something to it. Hope you have backups somewhere.
      I did have backups so that's the one good thing. I also thought someone did something but it is extremely unlikely. Nobody here knows what an alignment is & to do the same thing to both programs would take some level of pcdmis knowledge......dunno??
        If your IT group has not assisted you yet, to isolate the "Operator" mode (Read Only) so that folks around you can't modify the actual program, it would be a good idea to lock out any access to the Administrative priviledges on the PC associated with your CMM.
        We FINALLY installed our 7-10-7 and it was only running for a DAY, when an hourly Inspector decided to log on to the computer and start building files, with no permission to do so, and no knowledge of PC-DMIS or an automated CMM, whatsoever.
        Someone got in there, (innocently or not) and was "messin."
        -Soupy1957
        sigpic"I used to know what I was doing, but that was before I forgot!"
        -Soupy1957
        PC-DMIS 4.2/4.3MR 1
        Tutor
          Are you sure that they are not off the screen by 1500mm? Just a thought. Maybe PC-DMIS flipped a vector of a line. Just guessing here.
          sigpic GDTPS - 0584
          • dwade
            Iterative alignments
            by dwade
            I have a part that has no features that I can start an iterative alignment on the face of the part but have little flat surface or no features for setting...
            01-12-2007, 12:18 PM
          • zoran
            Corrupted program
            by zoran
            Is there limited number of alignments that I can use in a program? I am having problem when I add fifth alignment, program is getting corrupted. For some...
            03-31-2009, 09:40 AM
          • JoBLOCK
            Loaded v2009
            by JoBLOCK
            Had minor issues, but over all pretty smooth. I loaded from the CD
            11-24-2009, 09:53 AM
          • wicked_tattoo
            Iterative Alignment?? 3.7mr3
            by wicked_tattoo
            Whats going on everyone? I was wondering if anyone else has experianced problems on 3.7mr3 when trying to do a iterative alignment. I would ran a manual...
            07-11-2008, 03:00 PM
          • cappy6124
            Alignment help
            by cappy6124
            hey, i have this program, the iterative alignment works in offline mode, but will not work when i run the part. I get the always awesome, very non-descriptive,...
            05-10-2012, 03:33 PM
