centerline as Datum construction
  • centerline as Datum construction
    How does one construct a centerline feature to use as a Datum? Centerline of cylinder is the Z axis. Can the z axis be specified as a Datum, or the origin point ?
    Level to the Cylinder.
    Set the Origin to it also (XY).
    No Problem
    Bill Jarrells
      The axis of a cylinder can be used for LEVELING an axis and origining the OTHER 2 axis. It can kind of be used to origin the same axis as it levels, BUT ONLY if a minimum of 3 surface samples are measured for it, I think a AUTOFEATURE cylinder can, in this case, be used. I do NOT think a learned cylinder can be.
        Maybe you would like to make an Axis a feature?
        Then use a generic line set to 0,0,0, with a vector of 0,0,1 and a length of 2 inches or so. This would make a line running straight up in the Z axis.
        http://images.wikia.com/memoryalpha/..._his_Women.jpg
        G
          Depending on your part, it may be easier for you to measure a circle at the top and another at the bottom rather than a cylinder, (for example if your part has two different O.D.s but a common centerline). Sometimes it is not possible to create circles such that you can then make a proper cylinder from them b/c pc-demon "flips" the cylinder. However a 3D line between the two circles can be used to level to and set origin from, just the same as if it were a cylinder. HTH
            You can level to a point , or a line if you know what your doing.
            G
