I have a problem with one of our customers and a difference of opinion over ASME Y14.5M - 1994 section 2.7.1.2 Variations of Form (Evelope Principle). We have a bushing that is supposed to be ø.218 - .229". It does not have a circularity/cylindricity call out or anything of that nature on it. Measuring with calipers they found a two point diameter that measures .232", but the same part measured with pin gages comes up as .228". I say the parts are good as their MMC creates the envelope that they need. They say they are bad since the LMC violates the tolerance. I need a few more opinions to help me determine if I am right or they are right. Please chime in.
Envelope Principle Interpretation
All points must lie within that envelope, the problem is that you have a device that measures any TWO points. Not necessarily about the centriod of that feature.So try to get someone to buy into the principle that measuring a diameter with a caliper is not a best practice. (Good luck.) Maybe a full scan of the bushing, graphed could help.
Hmmm.
How much is that bushing?
There's an old saying:
"You can't save your face and your *** at the same time."
Gsigpic
Originally posted by Cumofo View PostAll points must lie within that envelope, the problem is that you have a device that measures any TWO points. Not necessarily about the centriod of that feature.So try to get someone to buy into the principle that measuring a diameter with a caliper is not a best practice. (Good luck.) Maybe a full scan of the bushing, graphed could help.
GsigpicSummer Time. Gotta Love it!
Technically you are probably going to lose this argument.
Calipers are the wrong tool. However, if you have dial bore gages you will probably find it over spec with those and you will have a hard time arguing against them. Intramic (ID Mic) is the best way but there are those who will never concede the dial bore argument.
Calipers are no good for accurate ID measurements.
Try to get them to buy into the ID Mics is your best bet.Bill Jarrells
IMO, measuring a diameter with a caliper is bad practice when a CMM is available.
Rule #1 states: Where only a tolerance of size is specified, the limits of size of an individual feature prescribe the extent to which variations in its geometric form, as well as size, are allowed.
IOW, if you want to use the caliper reading, the parts are bad. If you want to use a hard gage, the parts are good. But you are not checking form with either measurment.
It sounds like you may have a form issue with the bushing. I would run a multi-level, multi-point, max inscribed cylinder in the bushing and use cylindricity to check the form and compare that number to the diameter. Subtract the diameter from 0.229. This number is the tolerance for the form control. Size may pass but form may fail. 0.02sigpic GDTPS - 0584
Originally posted by inspector212 View Posthttp://www.pcdmisforum.com/image.php...ine=1181154602
I'll be at the Copacabana, BYOV
Bring Your Own Vole?
http://sp1.mm-a6.yimg.com/image/3502312135
"Hmmm, not tonight, I have a headache."
Gsigpic
This Tapered ID Gage is nice too. I have never had any complaints using this, as long as there was not a very visible out of round condition. These are also excelent for Plastic holes where a caliper would cut into the material.
http://i178.photobucket.com/albums/w...petedidmic.jpgsigpicSummer Time. Gotta Love it!
GBill Jarrells
Why do you argue with the customer? If he wants you to dance on your CMM using the bridge as the pole, do it. It's their part, throw the ball back in their court and ask them how they want you to check it.I used to be high on life but I built up a tolerance.
Originally posted by Goodluck View PostYou don't mention what this bushing is made of or how thick the wall is. Is it possible that a two point measurement is deforming the part .004?sigpicYou're just jealous the voices talk to me.
Screw the customer is always right. In this case he is full of sh!te. I may not win the battle but i'm gonna argue like heck that his way is crap..
DB posted before me......nevermindsigpic.....Its called golf because all the other 4 letter words were taken
Originally posted by Wingman View PostI think that is 'Bring Your Own Version (of a Barry Manilow Song)'
Everything you always wanted to know about homosexuality but were afraid to ask
Gsigpic
by george frickWe have always reported circle measurement using the least square evaluation. I was wondering if anyone uses the max inscribed or minimum circumscribed...
09-07-2008, 02:12 PM -
HI Everyone
I have been given a task of measuring the diameter of a cutter that we use that always seems to come in new too small. I have...-
04-20-2017, 06:37 AM -
Got something funny going on with my diameter measurements. I was wondering if someone could give me some insight. I am measuring a part thats outer diameter...
11-06-2014, 11:41 AM -
by JohnCTBI measure a lot of holes and core pins in molds. I read once (I believe in this forum) that a CMM is not the best tool for measuring diameters. I have...
05-19-2006, 01:48 PM -
by #2#I have a question of all you masters...
I know some, if not most of you feel that a CMM is not good at measuring inside diameters. I have...-
09-28-2006, 11:22 AM -
