I have a part that has two circular features. They are concentric and one feature has a diameter of 0.186" larger than the other one. The print shows a cross section of this area with a gap of 0.093" between the two features. Is there any way to inspect these two features with Auto Circle and report out the difference in radii to give me the 0.093" dimension? Can I do this in several places, for example the gap along the -X axis, +X axis, -Y axis and +Y axis?
Question on Reporting Circular Features
The difference in radii alone wont give you the gap correctly because the two features will not be concentric.
This will give you a very close answer:
Construct generic lines in the various orientations you need(angles) with the staring point of the lines being the center of one of the circles.
Intersect the various lines and the arcs.
Find the 2D distance between the points that define the gaps.
Create a 3d line through both and align the centerline, rotate, spit out that they are both 0,0. Use a variable and assign cir1.d-cir2.d/2.I used to be high on life but I built up a tolerance.
by Joe ArnoldWe have a circular disk with some holes, and slots with circular ends oriented about the center of the disk. How does one get the angular relationship...
10-22-2007, 03:31 PM -
by WolfManI have never tried that before, so I would not know if this is a bug or I am doing something wrong.
I have two lines that Intersect each...-
12-23-2013, 04:17 PM -
by Perry FisherI need some help from the gurus. Attached is sketch of a "D" shaped hole I'm trying to check. The 2 60° angles are what I need to report. The...
11-09-2007, 01:17 PM -
by BrandnewHey Everybody,
Wondered if you guys could help me out increase my learning curve. i have a circular object in which i need to measure...-
02-21-2009, 03:12 PM -
by UnderspecOk i'm getting annoyed by this v4.1 construction. I'm trying to get a mid-line between two lines and it's making it perpendicular to them instead.
06-18-2007, 02:31 PM -
