Imported cad file z axis
  • Imported cad file z axis
    If a cad file axis' is not oriented the same way as the pc dmis is there a way to change the axis or do you have to redo the axis in the cad file itself?
    That depends what version are you running?
      edit>preferences>part/machine or 4.1 and above or not sure about 4.0 I dont know what u call the feature but it changes the axis on the model. Toolbar at top of screen shows diff views. Master cam can do it as well . Sorry for the ramble burned out
        I believe what you are asking for is a Part = CMM thats in the " Edit, Preferences,Setup,Part/CMM. In Part/CMM go to Part Setup and change axis's. Place part on the CMM the way you want it, then put the cad on the screen so you can tell the CAD axis's to the Machine Axis's Is that clear to you?
          You can also use the operation/graphics windows/transform
            Only in 4+
