Maybe someone can help here...........This is a very straightforward dimension the distance between two paralell planes. I use two different angles one for each plane A90B0 on the back side & A90B-165 on the front side. I measure 3 points per side then construct bestfit planes>> then use 3d distance for the dimension. This has always worked in the past when compared to micrometer results.
Something happened?!!!<L
Now my distances are off .6mm compared to the micrometer. I thought maybe it was a crash so i repeated the measurement manually using the angles that i use in the program on a 3-2-1 block and got within .00019" Seems that its not a calibration issue....right? So then i added a bare bones alignment.. just leveled one of the planes and made that same plane x origin and tried to dimension location instead of distance. I get the same freakin results...aarg! What in the world is going on here?? this program has been running for 18months 24/6 any help is appreciated
