I replaced a TP20 last week because the machine quit responding to hits. You could see the probe touch the part multiple times in same place but no hits were being taken and no beeping. The same thing happened again with the next TP20 the next day. I would think it would be odd to have two TP20's back to back doing the same thing so I am suspecting something between the TP20and PH10. sometimes the led goes out when no touch is made to the probe and I lose the z axis control. re-homing corrects the problem but I feel that this is associated to the first issue. Now I have had no problem in about a week and I have been instructed to replace the TP20's but I'm not sure they are bad. Any way to verify this?
intermittent PH10 or TP20
Originally posted by calbritton View PostI replaced a TP20 last week because the machine quit responding to hits. You could see the probe touch the part multiple times in same place but no hits were being taken and no beeping. The same thing happened again with the next TP20 the next day. I would think it would be odd to have two TP20's back to back doing the same thing so I am suspecting something between the TP20and PH10. sometimes the led goes out when no touch is made to the probe and I lose the z axis control. re-homing corrects the problem but I feel that this is associated to the first issue. Now I have had no problem in about a week and I have been instructed to replace the TP20's but I'm not sure they are bad. Any way to verify this?sigpic
Originally posted by joe.sha View PostAre you using a magnetic fixture?? Tp20's and magnets don't play fair
When you say you are replacing the TP20 are you replacing the actual probe (screws onto ph10) or are you just replacing the TP20 module (the part the tip screws onto)?
by EllisantHello Everyone!
I was searching the forum but could not find solution for this specific problem:- I’m using DEA GLOBAL Classic with HH-MI-M
10-22-2019, 06:49 AM -
by ag162Hello Everyone,
I've recently upgraded to the PH10T and TP20. I had these in Atlanta and never had this problem, however I feel the need to ask...-
03-21-2006, 10:50 AM -
by scmanHas anyone ever heard of a module of a TP-20 on the end of a PH10MQ ever not triggering because of the magnatism of a steel mold.
When I get the...-
06-05-2009, 03:06 PM -
by danthecmmmanWhen running a program sometimes the CMM will just error out saying movement interrupted, and sometimes evens go as far as kicking the CMM out and i have...
04-15-2018, 10:31 AM -
by RandyHello,
Has anyone experienced TP20 Module failures? We have lost 3 standard force modules in the last week. Renishaw is currently looking at the...-
02-27-2014, 03:49 PM -
