I'm running 4.2, I've got some programs written, but when I got to run them, they do not have the coordinates that I put in> Any ideas???????
Will not save coordinates
When I wrote the program (offline and V4.1) whatever location of a feature or the moves to get there change. Here's an example;
FRSHRHI =FEAT/CONTACT/CIRCLE,CARTESIAN,IN,LEAST_SQR
THEO/<1599.4,585,-163.5>,<0,-1,0,18.2
This is what I programmed, and below is what it reads when I re-open the program and try to run it.
THEO/<1620.188,564.83,117.953>,<-0.3096724,0
Originally posted by RoadKill95 View PostI'm running 4.2, I've got some programs written, but when I got to run them, they do not have the coordinates that I put in> Any ideas???????
However, you must manually enter the nominal values each time you run this program in order to get a correct measurement. This bug are said to have been fixed in one of the later beta's. You can do a correct evaluation using the legacy method as it is not affected by this bug.
The bug appeared first in v4.2 and have been consistent in each and every release, beta or not, until later.PC-DMIS CAD++ 2o19 R1 SP11
Originally posted by vpt.se View PostI have reported this error to the nordic office since two months back. Somehow they didn't believe that it was a PC-DMIS issue, but rather an operator error. They had to send to technicians in order to believe it, the tech's had to experience the bug 'live'. Some support, huh...
The bug appeared first in v4.2 and have been consistent in each and every release, beta or not, until later.sigpic
Yeah, have tried that too, but it didn't help. It still messes with the nominals.
EDIT : I am dead tired of the 'fixes' that even tech support suggests - the software is meant to work - period. Apply the same 'fixing procedure' to your car or other stuff and it will get apparent how hilarous the entire thing is (which you all probably already knew).Last edited by vpt.se; 07-11-2007, 10:46 AM.PC-DMIS CAD++ 2o19 R1 SP11
by 12345I attached a portion of my program:
If you look at the theo's of the CDPLN1 and DCYL1,
the resulting point intersection should be 0,0,0...-
04-22-2009, 11:23 AM -
by Slug DawsonThe demon could not let me have at least one day without some sort of psycho issue. See the code below and please let me know why the machine is skipping...
11-23-2009, 04:31 PM -
by David WedelMy model has three target pnts that are off the cad surface. what i am wanting to do is drive my 3 pnts normal to the points on the surface and offset...
03-20-2015, 02:28 PM -
by tjackson2Using an ABC aligment (plane, line, plane) my coordinates are way off position. For example, I have a 13.5mm diameter at 153, 567.5, 0. theoreticals are...
05-15-2012, 02:54 PM -
by HRBK3I measured auto line (XLIN_P_9) with AutoLine function, and I constructed new line (LIN_POINT_9) from same autoline hits. When I checked line coordinates...
01-21-2014, 09:35 AM -
