I am trying to work in 4.2 (7-2-07) and am having some issues, 2, with auto move (avoidance move) in auto feature circle
1) When trying to probe a hole, the cmm is moving to a point about 8 inches above the feature prior to and after probing the feature.
If I turn off the avoidance move there is no issue.
2) When trying to probe an outside diameter using the avoidance move the distance above the feature is correct, but it drives from this point in a straight line 3D (moving over and down at the same time) to the first probing point thus hitting the part instead of avoiding contact as it should. After completing the probing it finishes by correctly avoiding by going up and then over to the center position.
any help on this one?
thanks
bob
thanks
bob
