I have successfully created a new report template (called TEXTONLYFORCALIBRATION.RTP) and successfully modified it. No big deal. I saved it and it shows up in the list of useable templates under the Templates Selection Dialog. I was also able to change from the default one to the new one in my program and it did what I asked it to do. Looked great until that point.
However, here is the issue: if I save my program and close PC-DMIS and then get back in and re-call my program, it ALWAYS reverts to the default TEXTONLY.RTP. When I use AUTOPRINT, it will only use TEXTONLY.RTP. I can not get PC-DMIS to use my new template, unless I re-open the program and select this my new template through the Templates Selection Dialog.
How can I make sure that for my program, PC-DMIS pulls up the correct RTP file? Not always the default one!
Thanks, Jan.
Thanks, Jan.
