Another reason I hate the new Pre-hit window in 4.2. You can not change the pre-hit size in the edit window. I want to change from 5 to 1, not working, will not let me change. Anyone have away around? Or is there a patch for that too?
Another reason I hare the whole new Pre-hit area
Originally posted by Paul Sarrach View PostAnother reason I hate the new Pre-hit window in 4.2. You can not change the pre-hit size in the edit window. I want to change from 5 to 1, not working, will not let me change. Anyone have away around? Or is there a patch for that too?
What do you mean by "pre-hit size"?
Do you mean pre-hit distance?
If so, then I would have to say move up. I have never had any problem with adjusting pre-hit distance in any of the 4+ editions. But, if you say you are, you are. Move up and it should take care of that and you're snap issue.sigpic
Take two hits before I Take two hits...
And then I take two more..
Jah meean da saaaample heets mon? Whuaat ja meeen my brujahmon?
http://mud.mm-a2.yimg.com/image/2296680057
Gsigpic
If you mean the spacing of the pre hits....
Show contact parameters=yes, sample hits=3,spacer=2
just change the number following spacer =
CIR54 =FEAT/CONTACT/CIRCLE,POLAR,IN,LEAST_SQR
THEO/<68.5,141.5,-58>,<0,0,1>,2.05,0,360
ACTL/<68.496,141.497,-58>,<0,0,1>,2.083,0,360
TARG/<68.5,141.5,-58>,<0,0,1>
ANGLE VEC=<1,0,0>
DIRECTION=CCW
SHOW ADVANCED MEASUREMENT OPTIONS=YES
REMEASURE=NO
SURFACE=THICKNESS_NONE,0
MEASURE MODE=NOMINALS
RMEAS=NONE,NONE,NONE
AUTO WRIST=NO
CIRCULAR MOVES=YES
CLEARPLANE=YES
GRAPHICAL ANALYSIS=NO
SCREEN CAPTURE=NO
FEATURE LOCATOR=NO,NO,""
SHOW_CONTACT_PARAMETERS=YES
NUMHITS=4,DEPTH=1,PITCH=0
SAMPLE HITS=3,SPACER=2
AVOIDANCE MOVE=BOTH,DISTANCE=5
SHOWHITS=NOIf I have offended anyone with this post, I'd like to take this opportunity to say BOLLOCKSDry your eyes Princess and man up.
It's da preehet mon
Ya mon, ya need to take a longa pree-heet mon, before ya take ya heet mon. A single sample heet is good for-ya-mon. Maybe mon, ya need to make youself a variable mon, and pass it to the left mon, then ya can tell mon, how far ya got to go mon, to take another heet mon.
You mon is righteous rastabrothu mon, you take a lot of heet at work mon.
Hard work good, hard work fine, but first take care of head mon.
http://re3.mm-a2.yimg.com/image/2206237035
Gsigpic
Dissociative Identity Disorder (DID), as defined by the American Psychiatric Association's Diagnostic and Statistical Manual of Mental Disorders, is a mental condition whereby a single individual evidences two or more distinct identities or personalities, each with its own pattern of perceiving and interacting with the environment. The presumption is that at least two personalities may routinely take control of the individual's behavior. The diagnostic criteria also calls for some associated memory loss that goes beyond normal forgetfulness, often referred to as losing time or acute amnesia.[citation needed] The symptoms of DID must occur independently of substance abuse or a more general medical condition in order to be diagnosed.
Gsigpic
Originally posted by Snaggy View PostF10, Prameters, Motion ?sigpicSummer Time. Gotta Love it!
Originally posted by xdodgemanx View PostIs this the Paul I know that should be working but choses not to. He would rather sit at the CMM and chat rather than work? Is this the same guy I know the could program a part then need his hand held to figure out what to do from there?sigpic
I just learned that pre-hit distance affects measurement accuracy, and does so by quite a bit. I suppose this is one of the things I would have learned...
11-13-2008, 01:02 PM -
by acgarciaGood Morning All:
The part I am inspecting is mostly composed of auto points so that I can utilize the avoidance moves and then construct...-
09-14-2016, 01:48 PM -
by quadman21When editing a program can I change the approach and retract distances individually for different features?
09-26-2012, 09:10 PM -
by B. JacobsHow would I change the prehit distance before a feature. I want to keep all the other prehits the same. I have a groove that I am trying to hit on one...
05-24-2006, 05:05 PM -
I am writing a program that has a measurement of small grooves. I put in a prehit and retract distance of 50 microns into the program, but when I go to...
07-26-2017, 09:29 PM -
