Angularity evaluations
  • Angularity evaluations
    How does the DEMON evaluate angularity? I've programmed a part from CAD and when I tolerance my line it shows me out by .039" and when I trig the angles from CAD I am only showing .03° off of nominal. The length of the line is only about .075" long.
    Should I use "T" instead and explain to the operator what it means?
    PNT10      =AUTO/VECTOR POINT,SHOWALLPARAMS = YES
                THEO/-0.1211,-1.5,-0.3713,-0.3826903,0,0.9238767
                ACTL/-0.1211,-1.5,-0.3713,-0.3826903,0,0.9238767
                TARG/-0.1211,-1.5,-0.3713,-0.3826903,0,0.9238767
                THEO_THICKNESS = 0,RECT,SNAP = YES,$
                AUTO MOVE = NO,DISTANCE = 0.04
    PNT11      =AUTO/VECTOR POINT,SHOWALLPARAMS = YES
                THEO/-0.0944,-1.5,-0.3603,-0.3826903,0,0.9238767
                ACTL/-0.0944,-1.5,-0.3603,-0.3826903,0,0.9238767
                TARG/-0.0944,-1.5,-0.3603,-0.3826903,0,0.9238767
    PNT12      =AUTO/VECTOR POINT,SHOWALLPARAMS = YES
                THEO/-0.0691,-1.5,-0.3498,-0.3826903,0,0.9238767
                ACTL/-0.0691,-1.5,-0.3498,-0.3826903,0,0.9238767
                TARG/-0.0691,-1.5,-0.3498,-0.3826903,0,0.9238767
    LIN5       =FEAT/LINE,RECT,UNBND
                THEO/-0.1211,-1.5,-0.3713,0.9241294,0,0.3820796
                ACTL/-0.1211,-1.5,-0.3713,0.9241294,0,0.3820796
                CONSTR/LINE,BF,3D,PNT10,PNT11,PNT12,,
                OUTLIER_REMOVAL/OFF,3
                FILTER/OFF,WAVELENGTH=0
                DIM ANGLRTY2= ANGULARITY FROM LINE LIN5 TO  THE XAXIS EXTENDLENGTH=0.0000 ANG=67.5000  UNITS=IN ,$
    GRAPH=OFF  TEXT=OFF  MULT=10.00  OUTPUT=BOTH
    AX    MEAS      NOMINAL     +TOL       -TOL        DEV      OUTTOL
    M      0.0398     0.0000     0.0020     0.0000     0.0398     0.0378 -------->
    Contura Calypso 5.4
    Input that .075" into the projected length area, perhaps that is where the variation is coming from?
      What work plane are you in.
        I was thinking just that.
          My part sits as if the the angled surface (a "V" milled into a stud) was sectioned perp to the Y axis. I have the work plane set to Yplus. I will try and change the length.
          Contura Calypso 5.4
