Hello,
The easiest way to describe it, from what I understand,,,it is kind of like true position, in relation to the vector and the compilation of x, y, z. Mainly used in sheet metal or stamping, but that depends on the customers requirements and surface points.
Hello,
A.Gore
I've never used sheetmetal either and what you just said, came in one ear, flew out the other
In relation to the vector??? i mean how does pcdmis calculate vector deviation and how is that used in conjuction with x,y,z deviation. Also if its something like TP where is the math....cant be anything alike.....
The math calculation is something I have never bothered with or questioned. But now that it has come to light, I will have to find the equation (sp?). We may have to wait till the main gurus get back to work. I will search for it later after work, since the internet is limited here. May have the answer by monday,,,sorry
T value is surface deviation... a plus value is extra material, a minus value it missing material... the calculation is x dev squared, plus y dev squared, plus z dev squared and the square root of that answer... hope that helps... if you need more assistance email me.
Dan
I have never turned on sheet metal in F5 key for the work piece which is made from sheet metal material. We have only one part made from sheet metal...
