FORMS editting
  • FORMS editting
    Anyone have a clue as to how to use CAD in a FORM? I go to the CADIMAGE OBJECT and insert it into a FORM and all I get is the HEXAGON block. If we manufactured HEXAGON blocks that would be nice, but, we don't so I need to use my CAD model. Any ideas? See link below.
    EXAMPLE
    I have played with this a little. What goes into the Form when you select the CadImage is whatever is displayed on you Graphics screen.
    Do you have that Block loaded in your graphics screen?
    B. Jacobs
    B&S Global 12.15.10
    2014.1
      Nope, I have my own CAD model of an HD transmission cover .
        I am not sure then. Thought I could help.
        I know mine just loads whatever is on my graphics screen.
        B. Jacobs
        B&S Global 12.15.10
        2014.1
          Have you executed the form? Mine shows the BS block when I build the form, but when I execute it it shows an image from my CAD file.
            I'm trying that right now. I actually opened up the HELP file. What a concept huh?
              James got Hog parts.
              hmmm...
              Hey James,
              Billet tranny covers for all your friends? Is it your model, can you share?
              G
                When I said mine I guess I meant the companies.
                  Ok, I executed the program from the point of the FORM insertion. I got the correct CAD to show up (I did this previously and it didn't work; though at that point I was offline).
                  Anyways my next question would be how can I insert dimension information into the form? I know look at the help file. Just thoughnt I would write back and say that the original issue is resolved.
                    Hi James.
                    As I understand it the main way of inserting dimension (or other) information into a Form is to use a parameter to change the Text property of a Text object inside your form using the FORM/FILENAME command:
                    For example:
                    ASSIGN/V1=LOC1.X.MEAS
                    CS2 =FORM/FILENAME= D:\PARTPROGRAMS\TESTFORM.FORM, AUTOPRINT=NO
                    PARAM/TEXT1.TEXT=V1
                    PARAM/=
                    ENDFORM/
                    Alternately, inside your form, in a Text object, you can change the Text property to:
                    =VARIABLE("V1")
                    The value of V1 will be the value of the Text object.
                      Thanks for the response Jared. I thought would be the one to answer. I don't know that I really need to do this as I look at the situation now. I tried the CADTEXT option for the template choice and that seemed to be ok. I also knew I could do a viewset and then shoot out a screen capture. Just trying out different stuff.
                      Again thanks.
