I had my LK machine changed over to PC-DMIS on Tuesday, Version 4.2 was installed, I'm using 4.1 on another CMM. When the machine was set up, the service tech calibrated only one of my spheres, I need the other one, but cannot figure out how to get the coordinates for it. Also when I added my angles for my probes (I use a star set up with 3 probes), it only gives one probe per angle, where in V4.1, it gives all 3 probes per angle. How do I get all 3 probes for each angle???
Calibrating a secondary sphere in V4.2
Originally posted by RoadKill95 View PostI had my LK machine changed over to PC-DMIS on Tuesday, Version 4.2 was installed, I'm using 4.1 on another CMM. When the machine was set up, the service tech calibrated only one of my spheres, I need the other one, but cannot figure out how to get the coordinates for it. Also when I added my angles for my probes (I use a star set up with 3 probes), it only gives one probe per angle, where in V4.1, it gives all 3 probes per angle. How do I get all 3 probes for each angle???
HERE'S 1
HERE'S 2sigpic
While calibrating probes, two of the probes in my 6 station rack went to find the sphere approximately two feet from where the sphere is actually located....
05-09-2013, 03:28 PM -
by grandpaal56WHEN QUALIFYING TWO DIFFERENT PROBES WITH EACH HAVING SEVERAL DIFFERENT ANGLES, HOW DO YOU RELATE THE THE TWO PROBES WHEN YOU HAVE TO SET-UP YOUR ARTIFACT...
10-17-2008, 02:01 AM -
by WilliganHi. I'm having a problem with multiple probes in a changer setup not being in sync after calibration. I'm running V3.7, a PH6 head, TP20, and MCR20...
06-15-2006, 09:59 PM -
by RoadKill95I'm having problems getting all of my probes to calibrate in DCC. I'm using a LK HC90, with a LH horizontal arm. My calibration sphere is set on an 45...
07-17-2007, 02:26 PM -
by jennyHello, I am building a star probe, here is my build, once calibrating this, I then check and my data -1.4mm off. Is this because I have the wrong exten...
07-10-2012, 04:21 PM -
