I am trying to move my trihedron with offsets. I have the orignal alignment put in when I try to off set the circle in the x and y I can only move in the x. When I enter the value for the y the trihendron does not move.
B&S global 3.7 mr2
STARTUP =ALIGNMENT/START,RECALL:, LIST= YES
ALIGNMENT/END
MODE/MANUAL
LOADPROBE/1BY20 MM
C1 =COMMENT/YESNO,NO,Would you like to do a manual alignment?
,If "YES" place part on large mag block
,ID end flush to front of block and using the
,1 inch starret gage block turn 90 degrees
,and place against right rail and part flush
,against that.
,Take 3 hits on top of part for plane.
,Take 2 hits front to back right side of part.
,Take 4 hits in ID of part for origin.
IF/C1.INPUT=="YES"
PLN1 =FEAT/PLANE,RECT,TRIANGLE
THEO/403.779,56.838,-501.399,-0.0048943,0.0016688,0.9999866
ACTL/403.779,56.838,-501.399,-0.0048943,0.0016688,0.9999866
MEAS/PLANE,3
HIT/BASIC,NORMAL,401.668,40.949,-501.383,-0.0048943,0.0016688,0.9999866,401.668,40.949,-501.383,USE THEO = YES
HIT/BASIC,NORMAL,406.063,53.988,-501.383,-0.0048943,0.0016688,0.9999866,406.063,53.988,-501.383,USE THEO = YES
HIT/BASIC,NORMAL,403.605,75.577,-501.431,-0.0048943,0.0016688,0.9999866,403.605,75.577,-501.431,USE THEO = YES
ENDMEAS/
LIN1 =FEAT/LINE,RECT,UNBND
THEO/408.964,34.777,-504.004,0.0032705,0.9999947,0
ACTL/408.964,34.777,-504.004,0.0032705,0.9999947,0
MEAS/LINE,2,WORKPLANE
HIT/BASIC,NORMAL,408.964,34.777,-504.004,0.9999947,-0.0032705,0,408.964,34.777,-504.004,USE THEO = YES
HIT/BASIC,NORMAL,409.025,53.245,-504.004,0.9999947,-0.0032705,0,409.025,53.245,-504.004,USE THEO = YES
ENDMEAS/
CIR1 =FEAT/CIRCLE,RECT,IN,LEAST_SQR
THEO/399.21,29.123,-504.535,0,0,1,11.004
ACTL/399.21,29.123,-504.535,0,0,1,11.004
MEAS/CIRCLE,4,WORKPLANE
HIT/BASIC,NORMAL,393.711,28.946,-504.535,0.9994803,0.0322366,0,393.711,28.946,-504.535,USE THEO = YES
MOVE/CIRCULAR
HIT/BASIC,NORMAL,399.054,34.623,-504.535,0.0282532,-0.9996008,0,399.054,34.623,-504.535,USE THEO = YES
MOVE/CIRCULAR
HIT/BASIC,NORMAL,404.691,28.654,-504.535,-0.9963559,0.0852927,0,404.691,28.654,-504.535,USE THEO = YES
MOVE/CIRCULAR
HIT/BASIC,NORMAL,399.469,23.628,-504.535,-0.0470571,0.9988922,0,399.469,23.628,-504.535,USE THEO = YES
ENDMEAS/
A0 =ALIGNMENT/START,RECALL:STARTUP, LIST= YES
ALIGNMENT/LEVEL,ZPLUS,PLN1
ALIGNMENT/ROTATE,YPLUS,TO,LIN1,ABOUT,ZPLUS
ALIGNMENT/TRANS,XAXIS,CIR1
ALIGNMENT/TRANS,YAXIS,CIR1
ALIGNMENT/TRANS,ZAXIS,CIR1
ALIGNMENT/END
END_IF/
C2 =COMMENT/YESNO,NO,Would you like to do a auto alignment?
,If "YES" the CMM will move DCC.
,The auto alignment will use the same
,features as the manual.
IF/C2.INPUT=="YES"
PLN2 =FEAT/PLANE,RECT,TRIANGLE
THEO/4.697,23.997,3.157,0.003073,-0.0006057,0.9999951
ACTL/4.697,23.997,3.157,0.003073,-0.0006057,0.9999951
MEAS/PLANE,4
HIT/BASIC,NORMAL,0.918,11.04,3.16,0.003073,-0.0006057,0.9999951,0.918,11.04,3.16,USE THEO = YES
HIT/BASIC,NORMAL,7.7,11.065,3.141,0.003073,-0.0006057,0.9999951,7.7,11.065,3.141,USE THEO = YES
HIT/BASIC,NORMAL,7.615,36.951,3.154,0.003073,-0.0006057,0.9999951,7.615,36.951,3.154,USE THEO = YES
HIT/BASIC,NORMAL,2.556,36.932,3.173,0.003073,-0.0006057,0.9999951,2.556,36.932,3.173,USE THEO = YES
ENDMEAS/
LIN2 =FEAT/LINE,RECT,UNBND
THEO/9.736,5.527,0.149,-0.0000336,1,0
ACTL/9.736,5.527,0.149,-0.0000336,1,0
MEAS/LINE,3,WORKPLANE
HIT/BASIC,NORMAL,9.736,5.527,0.149,1,0.0000336,0,9.736 ,5.527,0.149,USE THEO = YES
HIT/BASIC,NORMAL,9.734,13.2,0.162,1,0.0000336,0,9.734, 13.2,0.162,USE THEO = YES
HIT/BASIC,NORMAL,9.735,25.34,0.182,1,0.0000336,0,9.735 ,25.34,0.182,USE THEO = YES
ENDMEAS/
CIR2 =FEAT/CIRCLE,RECT,IN,LEAST_SQR
THEO/-0.004,0.001,-0.515,0,0,1,11.004
ACTL/-0.004,0.001,-0.515,0,0,1,11.004
MEAS/CIRCLE,6,WORKPLANE
HIT/BASIC,NORMAL,-5.497,-0.322,-0.493,0.9982677,0.0588361,0,-5.497,-0.322,-0.493,USE THEO = YES
MOVE/CIRCULAR
HIT/BASIC,NORMAL,-3.817,3.967,-0.494,0.6930492,-0.7208903,0,-3.817,3.967,-0.494,USE THEO = YES
MOVE/CIRCULAR
HIT/BASIC,NORMAL,1.78,5.206,-0.517,-0.3242304,-0.9459781,0,1.78,5.206,-0.517,USE THEO = YES
MOVE/CIRCULAR
HIT/BASIC,NORMAL,5.448,0.75,-0.54,-0.9907007,-0.1360593,0,5.448,0.75,-0.54,USE THEO = YES
MOVE/CIRCULAR
HIT/BASIC,NORMAL,1.896,-5.161,-0.533,-0.3453107,0.9384884,0,1.896,-5.161,-0.533,USE THEO = YES
MOVE/CIRCULAR
HIT/BASIC,NORMAL,-2.43,-4.937,-0.514,0.4409024,0.897555,0,-2.43,-4.937,-0.514,USE THEO = YES
ENDMEAS/
A1 =ALIGNMENT/START,RECALL:A0, LIST= YES
ALIGNMENT/LEVEL,ZPLUS,PLN2
ALIGNMENT/ROTATE,YPLUS,TO,LIN2,ABOUT,ZPLUS
ALIGNMENT/TRANS,XAXIS,CIR2
ALIGNMENT/TRANS,YAXIS,CIR2
ALIGNMENT/END
END_IF/
COMMENT/OPER,NO,When you hit "ok" CMM will measure
A2 =ALIGNMENT/START,RECALL:A1, LIST= YES
ALIGNMENT/TRANS_OFFSET,XAXIS,-44
ALIGNMENT/TRANS_OFFSET,YAXIS,36.5
ALIGNMENT/END
B&S global 3.7 mr2
ALIGNMENT/END
MODE/MANUAL
LOADPROBE/1BY20 MM
,against that.
IF/C1.INPUT=="YES"
MEAS/PLANE,3
ENDMEAS/
ENDMEAS/
MOVE/CIRCULAR
MOVE/CIRCULAR
MOVE/CIRCULAR
ENDMEAS/
ALIGNMENT/END
END_IF/
IF/C2.INPUT=="YES"
MEAS/PLANE,4
ENDMEAS/
ENDMEAS/
MOVE/CIRCULAR
MOVE/CIRCULAR
MOVE/CIRCULAR
MOVE/CIRCULAR
MOVE/CIRCULAR
ENDMEAS/
ALIGNMENT/END
END_IF/
ALIGNMENT/END
