Text Variables (CHR$)
  • Text Variables (CHR$)
    I want to assign a variable with a Character String. I have had limited success and know I am doing something wrong. Any help here?
    Example:
    I want to assign the word TEST to V1
    I type in:
    ASSIGN/V1 = 'TEST'
    or
    ASSIGN/V1 = TEST
    and I can use this variable to Report the location of a feature named Test. However, if I print the variable in a Comment then it returns a value of 0.
    How do I tell PC DMIS that a variable is a CHR$ Variable?
    Thanks.
    Bill Jarrells
    Are you quoting the comment string ie:
                ASSIGN/V1 = TEST
                COMMENT/OPER,NO,"This is the feature " + V1
    That may be your problem.
      Hmm.
      So, there is no way to declare a variable either character or number?
      I am not doint it that way. I simply do the COMMENT/ REPORT thing and enter in the variable. PC DMIS tells me that V1 etc is a variable and asks me if I want to use the variable. I say YES and a 0 shows up on the report instead of the word TEST.
      I will try it that way, but that alone won't solve other issues I am having with CHR$ Variables.
      Bill Jarrells
                    ASSIGN/V1 = TEST
        I tried it like this usiong empty quotes:
        "" + V1 and stiill reported 0
        It doesn;t appear that the variable is getting assigned as the text.
        Bill Jarrells
          try this
          AssIGN/V1 = "TEST"
          then the comment like Craiger has it
            Originally posted by T Miller View Post
            try this
            AssIGN/V1 = "TEST"
            That worked. But then I add 001 to it like this:
            ASSIGN/V2 = V1 + "001"
            and I get TEST1 instead of TEST001. I need TEST001.
            Bill Jarrells
              what about this ASSIGN/ = C1.input
              Sheffield Cordax RS-150
              SMP-350
              PCDMIS 3.7mr3
                Sorry, Assign/test = c1.input
                SMP-350
                PCDMIS 3.7mr3
                  Doesn't input require operator intervention? If so then it is not what I need. Hmm, maybe the TEST1 IS what I need though and not TEST001!!
                  Thanks,
                  Bill Jarrells
                    Yes, it would require you to plug in a value. I misunderstood what you are wanting to do.
                    SMP-350
                    PCDMIS 3.7mr3
                      Thanks for the response. It just looks like for some reason the Assign Command truncates off the preceeding zeros. Not a problem since I know what it is doing.
                      Bill Jarrells
                        All variables contain the value of 0 until execution (Documention says so). So the Prompt statement will show "0" until you run the program. The code listing will also show "0" until you run the program.
                        PCDMIS variables aren't declared in advance to be any particular type. The problem of the missing zeros is because PCDMIS is storing 003 as a number 3. If you put quotes about it (ie. "003") it would be stored as a string "003".
                        I have found that trying to manipulate strings within the PROMPT object dosn't seem to work too well. Its best to develop a variable with a complete prompt string prior to the PROMPT object then use the variable all by itself within the PROMPT.
                        I have been able to create a PROMPT using both a preset string and variable. But during each successive execution of the program another single quote would appear at the begining of the prompt in the PROMPT popup.
                          I finally got what I wanted to work. Still, putting quotes around the "001" and concatenating it with "TEST" resulted in TEST1 instead of TEST001. That's OK though and I can live with that even better after thinking about it for a while. I was getting ZERO because PC DMIS was using TEST1 and I was using TEST001. TEST001 was an empty variable so it returned the 0.
                          I haven't used the PROMPT with strings in any form yet but will keep this in mind.
                          Thanks,
                          Bill
                          Bill Jarrells
                            I have a sample snap shot of a program that appends 003 to a string.
                              Aha, there is a CONCAT command. I suspect that might be the difference. I used "TEST" + "001" and got TEST1
                              Thanks.
                              Bill Jarrells
