Is there a way for me to write into the beginnig of a program to detect which tips are used in that program and to have all of them calibrated? Similar to 'mark used' but done automatically.
Auto tip calibration in program
Andy,
Take a look at this thread. What the others posted should work. I use V3.2063, so don't try my code. I still haven't had time to look further into it here.
JohnWhen in doubt, post code. A second set of eyes might see something you missed.
OK, here it is. I have this saved as a 'template' program and any time I start a new program I open this and do a 'save as' and go from there. A couple of notes. As you will see, there is an if/end_if statement at the beginning that lets the operator choose if they want to see a document with setup photos. There is also an if/end_if statement that allows the operator to skip the calibration if it is not necessary. Usually we will run through the calibration routine before the first part and then run the other parts without the calibration. It is set up so the calibration results will be printed on the report if the calibration is run. I have set up saved sets so that it calibrates only the tip angles used in the program. I believe there are instructions on how to do that in the thread John linked to. You will notice that I have set it up so that for the first tip the sphere has moved so the operator will have to take a manual hit. The second one is set up so that the sphere has not moved and once the tip is on the probe, it will calibrate it without any operator motions. There are a couple of readpoints inserted in there before the command to change tips. Without those, sometimes it will skip prompting the operator to change the tip. Near the end there is another if/end_if statement prompting the operator to look at the standard deviation values and decide if they are acceptable. If they answer no, another comment is displayed and then the program ends. The last if/end_if statement simply ensures that the manual line is measured in the correct direction.
Let me know if you have any questions.
Code:PART NAME : template REV NUMBER : SER NUMBER : STATS COUNT : 1 STARTUP =ALIGNMENT/START,RECALL:, LIST= YES ALIGNMENT/END MODE/MANUAL CHECK/ 0.1,1 TOUCHSPEED/ 1 C1 =COMMENT/YESNO,NO,Do you want to view setup photos? ,If yes close window when done and click "Continue". IF/C1.INPUT=="YES"
Code:END_IF/ C2 =COMMENT/YESNO,NO,Do you want to calibrate tips? IF/C2.INPUT=="YES" LOADPROBE/4X20X30 TIP/T1A0B0, SHANKIJK=0, 0, 1, ANGLE=0 AUTOCALIBRATE/PROBE, PARAMETER_SET=806-106 4X20X30, QUALTOOL_MOVED=YES, SHOW_SUMMARY=YES, OVERWRITE_RESULTSFILE=YES BEGIN AUTOCALIBRATE RESULTS FOR PROBE 4X20X30 USING SET 806-106 4X20X30 Probe file=4X20X30 Date=12/18/2006 Time=8:56:50 AM Top Sphere CENT X 11.0435 Y 24.2910 Z -9.7849 D 0.7500 T1A0B0 THEO X 0.0000 Y 0.0000 Z 7.5402 D 0.1575 T1A0B0 MEAS X -0.0047 Y -0.0411 Z 7.5633 D 0.1564 StdDev 0.0001 T1A90B0 THEO X 0.0000 Y 6.1622 Z 1.3780 D 0.1575 T1A90B0 MEAS X -0.0367 Y 6.1517 Z 1.3891 D 0.1565 StdDev 0.0001 T1A90B-90 THEO X 6.1622 Y 0.0000 Z 1.3780 D 0.1575 T1A90B-90 MEAS X 6.1855 Y 0.0027 Z 1.3905 D 0.1566 StdDev 0.0001 T1A90B90 THEO X -6.1622 Y 0.0000 Z 1.3780 D 0.1575 T1A90B90 MEAS X -6.1837 Y -0.0697 Z 1.3822 D 0.1565 StdDev 0.0001 END AUTOCALIBRATE RESULTS FOR PROBE 4X20X30 USING SET 806-106 4X20X30 PNT1 =FEAT/POINT,RECT THEO/1.3466,15.9335,-13.3308,0,0,1 ACTL/1.3466,15.9335,-13.3308,0,0,1 READPOINT/ LOADPROBE/2X20X20 TIP/T1A0B0, SHANKIJK=0, 0, 1, ANGLE=0 AUTOCALIBRATE/PROBE, PARAMETER_SET=806-106 2X20X20, QUALTOOL_MOVED=NO, SHOW_SUMMARY=YES, OVERWRITE_RESULTSFILE=YES BEGIN AUTOCALIBRATE RESULTS FOR PROBE 2X20X20 USING SET 806-106 2X20X20 Probe file=2X20X20 Date=12/18/2006 Time=9:00:05 AM T1A0B0 THEO X 0.0000 Y 0.0000 Z 7.9339 D 0.0787 T1A0B0 MEAS X -0.0190 Y -0.0275 Z 7.9728 D 0.0777 StdDev 0.0001 T1A90B-90 THEO X 6.5559 Y 0.0000 Z 1.3780 D 0.0787 T1A90B-90 MEAS X 6.5951 Y 0.0186 Z 1.3769 D 0.0779 StdDev 0.0001 T1A90B0 THEO X 0.0000 Y 6.5559 Z 1.3780 D 0.0787 T1A90B0 MEAS X -0.0525 Y 6.5612 Z 1.3753 D 0.0777 StdDev 0.0001 T1A90B90 THEO X -6.5559 Y 0.0000 Z 1.3780 D 0.0787 T1A90B90 MEAS X -6.5932 Y -0.0857 Z 1.3679 D 0.0776 StdDev 0.0001 END AUTOCALIBRATE RESULTS FOR PROBE 2X20X20 USING SET 806-106 2X20X20 C11 =COMMENT/YESNO,NO,Please review the calibration results in the edit window. ,Are the standard deviation values acceptable? IF/C11.INPUT=="NO" COMMENT/OPER,NO,Please re-start the program and run the calibration again. PROGRAM/END END_IF/ END_IF/ PNT2 =FEAT/POINT,RECT THEO/1.3554,15.9588,-13.7291,-0.0025616,-0.0091396,0.999955 ACTL/1.3554,15.9588,-13.7291,-0.0025616,-0.0091396,0.999955 READPOINT/ LOADPROBE/4X20X30 TIP/T1A0B0, SHANKIJK=0, 0, 1, ANGLE=0 FORMAT/TEXT,OPTIONS,ID,HEADINGS, , ;MEAS,DEV,OUTTOL,NOM,TOL,DEVANG, L1 =LABEL/ LI2 =AUTO/LINE,SHOWALLPARAMS = NO,SHOWHITS = YES THEO/0,0,0,1,0,0,1 ACTL/0,0,0,1,0,0,1 TARG/0,0,0,1,0,0 MEAS/LINE HIT/BASIC,0,0,0,0,0,-1,0,0,0 HIT/BASIC,1,0,0,0,0,-1,1,0,0 ENDMEAS/ IF/LI2.I<.9 COMMENT/OPER,NO,Line Hits Must Be Taken From Left To Right GOTO/L1 END_IF/
You're welcome.
BTW, I have in the past played around with another if/end_if asking the operator if the sphere has moved before the first calibration. If they answered 'yes' it would kick them to a calibration set up prompting a manual hit and if they answered 'no' it would kick them to a calibration set up so that they didn't have to take the manual hit.
It worked but I decided it really wasn't worth the extra code and the risk of the operator answering 'no' and maybe having it take off and crash into a part on the table.
Originally posted by DaddyBluto View PostAre the two readpoints in your code actually used for anything?
One Thing I forgot to mention...
After it finishes calibrating all the angles for a probe it will rotate to A0B0 without moving up. So, if the last angle calibrated is A90BX it will pull away from the sphere like and inch or something and then rotate to A0B0. If you are using a probe build that is longer than the height of your cal. sphere it will hit the table. For this reason, I have my cal. sphere elevated from the table by about 6". I simply got a 6" diameter steel round about 6" high and drilled and tapped a hole in the top to attach the cal. sphere. I was lucky and the round didn't rock right of the bat. If it rocks, you would need to attach some feet or have then end ground flat or something. I like it this way as the 'base' is heavy enough that I don't have to attach it to the table and I can move it around easily. Also, I can calibrate tips without moving shorter parts that may already be clamped to the table.
by giantslayerI recently changed my auto calibration program. I changed what tip I use to calibrate from. When I run the program all the tips seem to calibrate fine...
08-20-2014, 01:54 PM -
by cappy6124hey all,
When running an auto calibration, at the end of the routine, the probe always goes back to tip a0b0, is there any way to change...-
07-18-2013, 11:25 AM -
by RichVPAll,
Is there an easy way to find out what tips we use in a certain directory? Then I can do an analysis of that and find out what tips...-
02-08-2016, 08:39 AM -
by mhackman72Hi,
The probe calibration program currently on our CMM begins each tip probing in the 90 -90 position. I started to make a new calibration...-
05-21-2014, 01:24 PM -
by UnderspecWhen inserting a tip calibration in the program, I can't choose a specific tip. I would think it's possible. Anyone know how?
I'm...-
10-25-2006, 04:18 PM -
