Any body know how to correct this error? I am not being shut down over it I just switch to RS-232. I believe it has to do with having the machine set up for scanning, but not having a scanning head.
TCP/IP Error
It means it's not connecting to your controller. You will have to restart your controller and pcdmis to re-nsyc. RS-232 is an old serial connection. TCP/IP is the newer connections using RJ-45 (networking) connection. I'm assuming you have a controller capable of supporting a scanning head that's why.I used to be high on life but I built up a tolerance.
by djone368does any one know what this error means
I have to answer yes or no
thanks-
06-03-2007, 11:15 AM -
by jon_dav_ukDoes anyone know how to get the static IP Address of a controller (B3CLC).
We have a new PC but cannot get it to talk to the controller...-
10-30-2008, 03:06 PM -
by Mike LarsonCould anyone help me out with the following error that has been showing up on our Global 7 10 7.
We are currently using version 4.3 MR2 software....-
07-23-2013, 12:31 PM -
by GEllsworthUpdated the computer and now a TCP/IP error is happening. I tried searching some of the threads with no luck. I recall it has to do with a network setting...
12-15-2012, 11:40 AM -
by volsmoThe TCP/IP settings on our CMM computer have been lost. Can anyone tell me the proper IP settings for a Brown Sharpe Global Performance CMM.
We...-
03-09-2010, 09:09 AM -
