Does this behave 'exactly' as stated in help file? Are there any caveats to turning it on or off?
Allow Fine Tuning Of Alignment
Turn it on and leave it on. From what I have been able to figure out:
1) It applies to 3-2-1 (cad=part) alignments
2) It allows you to make small adjustments to the offset values of the alignment and conciders them ALL as 'major' adjustments, and thus asks you IF you want to update all the commands that follow.
3) If it is NOT turned on, small adjsutments (how small, I can not tell you for sure) will NOT prompt the update warning, but I do NOT know if Pcdmis then does NOT update or if ti DOES update.
Better safe than sorry, is my reason for leaving it on, I WANT THAT PROMPT, I do not want it left to Pcdmis to decide whether to update or not.sigpic
Wingman,
I have wondered this myself. It says that this changes ONLY machine to part transformations when selected. When deselected it will not allow the transformations to happen. According to the help file it will still prompt you for alignment updates but will not do machine to part transformations it considers necessary. Who knows exactly what it means. I have always been afraid to turn it off. Any help from the B&S or Hexagon guys on here?sigpic
by terchan1Hi All,
I 'm looking for a function which can update the dependent commands after I update the alignment setting (Shown in attachment)...-
Channel: PC-DMIS Code Samples
08-07-2014, 06:21 AM -
by WolfManWhen you make a change inside the alignment in the middle of the program, then click OK, normally there are two questions: 1. Is to update the alignment...
12-01-2015, 11:38 PM -
by T.ElderProgrammers,
I am interested in "saving alignments" and "recalling" them in other programs. However when I recall...-
06-26-2007, 04:43 PM -
by kingsld1PC DMIS 2014.1 X64 Build 767 Service Pack 2
When changing or adding an alignment the update dependant commands prompt is NOT appearing....-
04-09-2015, 01:35 PM -
by DaSalo"Update Theoretical Values in While Loops"
Can someone remind me what this check box does (F5=>General)? It isn't in the documentation...-
09-05-2013, 12:46 AM -
