IGES Origin in space?
  • IGES Origin in space?
    I can import iges files alright, but the x,y,z origin on the model is somewhere in space. Our models are given to us with Airplane Coordinates and I believe that the orgin I see is this. We have tried to set a good origin in Unigraphics, but it still shows far away after importing. I have tried to manually set up the origin on the part, but the graphics still show my probe and features near the space origin, even after chosing CAD=PART. Is there a trick at the Unigraphics stage or somewhere in PC-DMIS that I can get this right?
    Use an ITERATIVE alignment for airplane, I have heard that works best.
    Also, I know you said IGES, but STEP files can be issues. There are 2 forms of STEP, one of them will stay in original orientation no matter what you do to the model upon export, the other one will export the model to what you have done for moving the data around.
      Try using the Operation-Graphics Display Window-Transform feature to edit the CAD model to where you want the origin.
        What version DMIS are you running?
          I am using 4.1
          I do not understand "Iterative"
          Can you explain?
            Shirley you must be joking?
            sorry, lame hijack attempt
            If given to you in airplane coordinates, wouldn't you want to report in airplane coordinates? If you're reporting in airplane coordinates, wouldn't you want to measure in airplane coordinates?
              Do as underspec has suggested
              I am using 4.1
              Can you explain?
              A method of alignment construction that refines itself by measuring and remeasuring the alignment features created by the programmer. See the linked document for more info.
              GO HERE FOR DOCUMENT
                Ditto on the iterative - I'd keep everything in airplane coordinates. That way, everybody is on the same page.
                Another way, is to use the iterative alignment, then a 3-2-1 alignment to your own coord system. This will snap the model to where you want it. I used to have decent luck doing that.
                  http://mud.mm-a4.yimg.com/image/2864581177
                  Don't call me Shirley...
                  1) write a short alignment routine "offline style" with mouse.
                  2) execute the routine in manual mode.
                  3) the part axis and origin will be exactly where you want it.
                  K?
                  it''s easy, DO NOT USE CAD=PART!!!!!!!!!!!!!
                  G
                    Well, no I do not want to report Airplane Coordinates. How am I suppose to tell the operator that the .125 diameter hole at 105 inches is out? Plus, the Airplane coordinate does not match any alignment of the part. I can get the CMM to check the part, but I have no nominals. I have tried Iterative alignment, but my origin does not change. I even used the wizard, but no luck. All I really want out of life is that the little picture of my probe in the graphic display is where it physically is on the CMM. HMMMM. Maybe I am just an idiot but I am really stuck.
                      Wgs
                      Tk
                      sigpicHave a homebrew
                        Mike I told you how to fix it. Now do it.
                        (Forget what the probe looks like here it will come around ok.)
                        (with the part on your table exactly as you like)
                        3) the part axis and origin will be exactly where you want it, and you can smile again.
                        K?
                        G
                          Do what cumofo said in his post and the CAD will be right where you want it.
                          Bill Jarrells
                            I do this all the time. Works great to get your model origin to match the ABC origin of the drawing.
                            ** "Well, ain't this place a geographical oddity. Two weeks from everywhere!"~ Ulysses Everett McGill **
                              Can you post the drawing of the part you're measuring - we could probably give you a play-by-play of how to set the origin in the CAD window. It's fairly simple - once you do it the first time, it'll be a piece of cake from then on.
