How do I set up a linear open scan without CAD?
Scanning without CAD
After you do you alignment, turn on your DCC, then just hit on part where you want to start, then hit again for direction and finally hit where you want it to end. You should square up your part to the table first for best results. I also will turn of the axis I am going in on my hand held joystick.sigpicSummer Time. Gotta Love it!
Originally posted by Paul Sarrach View PostAfter you do you alignment, turn on your DCC, the just hit on part where you want to start, then hit again for direction and finally hit where you want it to end. You should square up your part to the table first for best results. I also will turn of the axis I am going in on my hand held joystick.sigpic
Originally posted by JamesMannes View PostOnce you are done with what Paula said go and clean up your cut vector stuff (make it 0,1,0 or whatever you vector may be). This will allow the scan to stay on path at one value. Make sense?sigpic
Thanks guys (and you too Paula). Really it is setting it up the same as from CAD but you take the start, direction and end points with the probe. Sounds easy enough.Xcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
Tried and it only took 4 points across the surface and it is only about 25° of 170° total arc I picked. I have tried to alter my settings but no luck. I am using a open linear scan with points to be taken every .050" (arc length should be about .75"). Projection is on the working plane.
Should I be using one of the other scan options? Section? Basic line?Xcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
Originally posted by dwade View PostTried and it only took 4 points across the surface and it is only about 25° of 170° total arc I picked. I have tried to alter my settings but no luck. I am using a open linear scan with points to be taken every .050" (arc length should be about .75"). Projection is on the working plane.
Should I be using one of the other scan options? Section? Basic line?sigpic
Thanks Matt. One direction boundary is 1 and the other directino boundary is 2. Works like a charm.Xcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
