I have a plate w/ a pattern of thru holes (.169"), which also have counter-bores (.300"). Is there a way to copy the pattern of thru holes, which I have already programmed, offset them in Z to the top of the counter bores, adjust for the new diameter and paste w/pattern?
Pattern question
Trying to do too many things for pattern paste. Why not copy it then do a search / replace for the things you need? Feat name, Dia, Z depth.Bill Jarrells
A lie can travel half way around the world while the truth is putting on its shoes. - Mark TwainComment
** "Well, ain't this place a geographical oddity. Two weeks from everywhere!"~ Ulysses Everett McGill **Comment
Or, just copy one, paste with pattern in Z. Then change the diameter, copy and paste with pattern for the X,Y locations.When in doubt, post code. A second set of eyes might see something you missed.
sigpicComment
by BANDYI need to check 122 same dia holes on part and I wonder how do I select all of them and program this holes. Its kind of a pain doing it one-by-one.
09-01-2006, 11:39 AM -
by catguyUsing ver 2011 MR1 and doing some offline programming. I have a part that has a 4 hole pattern around the XYZ origin and I use paste with pattern to create...
01-05-2012, 09:23 AM -
by swisk212What am I doing wrong ? I have used paste with pattern previously - -pattern and put in offsets and number of times then copy & paste with pattern...
11-27-2019, 02:31 PM -
by homer.tanHi,
I am using 2011 MR1 and try to use edit|pattern and edit|paste with pattern in the program, but it doesn't work now(it works sometime...-
04-13-2012, 02:30 PM -
by gage guruOk have 20 holes to measure and want to do paste with pattern. I understand how to do the paste with pattern and it works fine, but I want to make life...
05-25-2006, 05:42 PM -
