Drawing Indicates a group of holes true position to datums A-B-C within .008 , regardless of feature size. Where do I put this information, so the machine knows this? Thanks to all for the help.
Patrick
I don't feel tardy!sigpic
B&S "One" V4.2
Discovery D-12 V4.2
Your BASIC DIMS should be your X,Y,Z theoritical. In your auto features just enter these from in the XYZ boxes. Just remember to set your origin correctly. Then dimension accordingly with the correct axis.
Patrick
You assign the 0.008 TP in the True Position Window. Near the top of the window it will say Tolerances and there will be a drop down box. Open the drop down box and find TP and select it. Enter 0.008 in the Value Boxes.
Once you have selected the feature you want to tolerance from the feature list click create to add the tolerance command to your program.
Bill Jarrells
Measure A, align to it and define it as datum -A- (Insert/Dimension/Datum Definition)
Measure B, align to it and define it as datum -B-
Measure C, align to it and define it as datum -C-
Make sure that Insert/Dimension/Use Legacy Dimensions is NOT Checked!!!!
Then proceed to insert the call using Insert/Dimension/True Position.
It will give you a lot of info about where the hole is with repect to the datum structure.
Jan.
I have a 4 hole bolt pattern which is the customer mounting feature. They want a (4X) true position on these holes to an ABC alignment, so that was easy...
I recently did a true position and may 321 alignment to the datums and picked the feature to be true positioned but I get a smaller TP than if I do a...
I have little to no experience using true position. The concept I need to grasp is this. Does the part alignment datums have to be the same as the datums...
I am trying to measure a part with 4 holes aranged about a central bore that is datum B. There are basic dimensions to the 4 holes from the bore axis,...
