PDF printing pop up even with printing turned off
  • PDF printing pop up even with printing turned off
    I'm not sure if someone on another shift has possible turned something on but when I came in today, everytime I execute a feature using ctrl U/Q at the end I get the printing prompt below. Printing is turned off under File>Printing>Report Window Print Setup. We typically just produce .rtf and .dmo and rarely use pdf. Any idea how I can turn this off? 2022R1 is what we're using if that matters.
    press ctrl+shift+esc > if you see spooler.exe end the task or reset it to see if that corrects it.
      I'm not seeing that
        something like this in processes.​
        its what the o/s uses to handle print jobs​. windows 7 they call it spoolsv or something like that.
          Okay I found it in background tasks. It's saying I need admin rights to end task
          • KatmandudaMeow
            KatmandudaMeow commented
            IT has it locked down then. Rebooting the computer will do the same thing...
          In the report window, click on the SAVE/PRINT THE REPORT icon, is the File Output checked? If so, uncheck it.
          I miss seeing the Datum Shift in Geometric Tolerancing. Do I start a GoFundMe or something to bring it back?
          • bfire85
            bfire85 commented
            MuyGuapoMatt Have you tried uninstalling and re-installing the PC-DMIS PDF Drivers?
          • KatmandudaMeow
            no change your print report option to PCDMIS 50 Converter. i think thats your issue.
          • bfire85
            bfire85 commented
            KatmandudaMeow No. That is not it. See my response to you below. This is now sounding like a Amyuni printer driver issue.
          its seeing it to print to this last location. thats why.
            sounds like the "AMYUNI" issue
            open settings editor
            FIND "amyuni"
            Entry Name: DoNotUseAmyuniRTF
            Entry Type: Whole Number to specify RTF output option. Default value is 0.
            amyuni set value to 0
            DoNotUseAmyuniRTF is used to let pcdmis output RTF output in a more plain text output which allows 3rd party RTF parsers to work.
            This is mostly used when dimensions are being output in plain text mode. Not all reporting objects (such as the CAD reporting object,
            nor Text object for page number) do not output in this format.
            Output Option Key:
            0 - use Amyuni to generate the RTF. To do so, they generate a PDF and convert to RTF. Mostly images which result in a large file.
            RTF output uses Amyuni RTF output.
            1 - use the output setting at start of execution to determine what RTF out to use. People who do not use a PRINT command can use this.
            RTF output uses the old style RTF if you have selected the RTF output option via the Report Print Options dialog box before the program was executed.
            Setting the PRINT/REPORT command to RTF will not work correctly for this value.
            2 - force pcdmis to use MS RTF control to generate RTF output. People who use the PRINT command to output plaintext RTF use this.
            RTF output uses the old style RTF even if you have not set the option to “Print to RTF” in the Report Print Setup dialog box before the program was executed.
            This is useful for the Blade program where the wrong control would be used for reporting resulting in nothing being output if the flag was set to 1.
            Under all conditions the correct text object is used to display text in the report window.​
              It's not checked so it's not going any where...if it was checked it would print to that printer.
                The Concatenate on the dialog indicates it is an Amyuni dialog being displayed. There is a registry setting that needs permissions.
                Search for Amyuni to find it as I can’t remember it.
                For future reference the registry setting is H_KEY_CURRENT_CONFIG/SOFTWARE/PCDMIS 50 CONVERTER the logged in PC user needs to have full access rights to this registry setting to allow print commands to work in Windows10​
                  So to update, I went into settings editor and Amyuni is set to 0. Also under save/print report its now set to PC-DMIS 50 Converter. With printing turned off, I'm still getting the PCDLRN pop up every time it executes a feature/features using CTRL U/Q or I cancel.
                  • SABarber
                    SABarber commented
                    Did you check the registry setting mentioned above for permissions?
                    1. you cannot (or should not try to print directly to the PCDMIS Converter or Amyuni as a printer. Amyuni is for PDF/RTF output and pcdmis must provide a license to print to it.
                    2. The Report Output dialog above is used to manually print the report to an output type. Again, pcdmis will internally use Amyuni for file PDF/RTF output.
                    3. The output is generated at end of execution based on either a PRINT command or File/Printing/Report Window Print Setup. Selecting Report output for file output (upper portion of the dialog) controls what file type is generated. I'm assuming you have NOT selected Printer.
                    4. Once execution is complete pcdmis looks at the output type selected and tries to output to your selected type using the Amyuni Print Driver. The driver is attempting to change the above mentioned registry setting but is unable to and displays the Amyuni dialog which you have attached in your first comment (the one which contains Concatenate).
                    5. If you correct the registry setting permissions is there still an issue?
                  Uninstall and reinstall the PDF drivers.
                  Located in: C:\Program Files\Hexagon\PC-DMIS {Your Version}\PDFDriverInstallFiles
                  PCDMIS should not be loaded when performing the next 2 steps.
                  BatFileInstallPDF50.zip: contains the needed files
                  1) Removing the previous drivers
                  BatFileInstallPDF50.zip contains InstallPDF50.exe and UnInstallPDF.bat.
                  Unzip these files to a temporary location. Double click on the UnInstallPDF.bat file.
                  A dialog should be displayed saying the pdf driver is removed. This will remove other instances of the driver if they are present.
                  Close the dialog.
                  Close the COMMAND screen by pressing ENTER.
                  (added instruction) Reboot the Computer.
                  2) Installing the PDF Suite drivers
                  Unzip the BatFileInstallPDF50.zip files to the pcdmis directory.
                  There is also an UnInstallPDF.bat file which may be used in Step 1 above.
                  Double click on the InstallPDF50.BAT.
                  A dialog should be displayed saying the driver is being installed.
                  Close the dialog.
                  (added instruction) Reboot the Computer.​
                    This is related to at least two other forum reports -
                    Recently our computers were upgraded from Windows 7 to 10. Since that upgrade, the report to file command has needed the operator to prompt the file to save when that was not necessary before, it just saved automatically. Has anyone else experienced this and is there a fix? Assignments, tracefields and print commands
                    We have our programs set to "prompt" when exporting a pdf report to a specified folder we setup in the print report setup page. Normally, when we press the "print report" icon, you begin to see the small dialogue box showing that its printing each page to the specified folder. Fast forward after what
                      Did someone add a print command to the routine itself? Like the Insert>>Report Command>>Print Command?
                      It's also possible that you can trigger printing from a script. Are you calling any scripts at the end of your routine?
                      • mconklin
                        Printing in pdf
                        by mconklin
                        I am having problems with printing a report window to a file instead of a printer. This is the error it keeps getting....
                        12-06-2010, 04:54 PM
                      • Kingkrab
                        Printing issues
                        by Kingkrab
                        Text mode dimensioning. 2010mr3.
                        When I print the report, part of the text is missing, just the bottom half of any given line.
                        For example,...
                        02-19-2013, 02:55 PM
                      • Gootsis
                        Question about Printing
                        by Gootsis
                        Hello, I'm still kind of new to this. I have a problem with my reports automatically printing every time I run the program. Is there a setting that...
                        05-13-2016, 12:44 PM
                      • gnichols73
                        printing issues
                        by gnichols73
                        I have a program that runs 2 to 3 days a week on 3 shifts, we run this program twice an hour. The operators on the floor are running 2019r1 operator mode....
                        06-30-2021, 01:34 PM
                      • Tomi530i
                        Printing report
                        by Tomi530i
                        Right after my program stop running the printer is printing the report. It never did that before. Do you know how I can turn it off so it does not print...
                        09-16-2008, 10:48 AM
