Getting wacky numbers here. Alignment is set. Points are taken along the x-axis. I'm doing a 3D distance (X). The distance is not matching what i get subtracting one of the points (x) to the other (x).
point to point distances - (3d)
3-D will give you the total deviaiton betwee the points in 3-D space. If there is a Y axis or Z axis difference, it will be incuded in the result along with the X axis deviation. If you only want the X difference, use 2-D distance (IN the Z workplane) parrellel to the X axis or PERP to the Y axis.sigpic
Ouch !!
I'll have to comfort myself with some good Scotch !!
Would anyone care to join me? It's been a long week.
Things are becoming "interesting" around here. Our facility is "transitioning" the business out of our "little" plant to a couple of the "bigger" sister facilities.
Don't know where I'll be headed to. Hopefully, it will be somewhere that I can continue to associate myself with you good "folk".
Blessings,
ZydecoPetesigpic
by Abdul Rehmancan anyone please help me out for understanding the concept of 2D & 3D distance in dimension and also about 2D, 3G angle mesurment in Angle dimension...
03-19-2015, 11:13 AM -
by AuRulesDo anyone have a good explanation of the difference between 2D & 3D distance. I hit the F1 key and read the definition. But maybe it's me or I just...
05-16-2007, 02:59 PM -
by rochcncOk.I'm going from a plane face to a hole/cylinder.
which is better-more accurate.2d or 3d.
I'm suer that 3d would be the most accurate....-
09-15-2009, 11:35 AM -
by taasncWhen should you use a 2d distance compared to a 3D distance?...
07-05-2016, 05:17 PM -
by jdkhunterHow do you measure z distance between two features. for instance two points at different x & y locations?
04-23-2007, 06:12 PM -
