Anyone seen this before? Showing me out of deviation but i'm not!
Tip calibration showing out of deviation
Originally posted by Underspec View PostAnyone seen this before? Showing me out of deviation but i'm not!
Now on to your problem (PC-DMIS problem). Did you try increasing your SD tolerance, then setting it back to what you need. It is possible something got entered wrong. Changing it may correct that error. I'm thinking there might be a minus sign in the tolerance, can't see it due to the size of the box. I did that with a part tolerance one day and was going nuts trying to figure it out.Last edited by John Kingston; 06-21-2007, 11:55 PM.When in doubt, post code. A second set of eyes might see something you missed.
I've deleted the tool and created a new one but still does the same. All the probes on the rack calibrate this way. B&S said they are confused as well. Thought maybe one of you guys have came across this problem.I used to be high on life but I built up a tolerance.
Pretty tight. We qualify our tips at up to .0004" SD (metric up to.010mm SD).
Maybe its' doing some sort of rounding?Last edited by JamesMannes; 06-22-2007, 10:44 AM.sigpic
by TCeckelsThis morning I calibrated the tips I needed to run the program I was working on... (Mark Used / Measure) and after running the chosen tips around the...
02-20-2009, 04:45 PM -
by DHoyeWas wondering if anyone has had this problem...My report says nominal, +tolerance,-tolerance, deviation, and out of tolerance.....when measurement is...
03-11-2008, 10:28 PM -
by LGDCMM3RDUsing PCDMIS CAD++4.2MR3, have calibration setup set at a .0008 tolerance in the diameter and .0004 tolerance in the deviation. Software is kicking out...
08-15-2011, 03:16 PM -
Cant figure out what it is. I have a 1mm TP20 on an SM25 base. After restarting my machine and PCDMIS, I started getting a deviation of .02 mm when trying...
02-06-2015, 01:14 PM -
by EmilySueHI All,
I just wrote a new program for the first time in quite a while, and the report is not calculating "out of tolerance" correctly....-
08-31-2018, 04:21 PM -
