how do you use the auto symmetry command properly?
symmetry
by Rob_KSee attached Symmetry 0.5; I say BAD; need some backup on this one...
Please HELP!!!-
07-12-2007, 09:15 AM -
by JVau425033Can some one tell the best way to do symmetry of two radius?
06-20-2012, 06:21 PM -
by EEC1959I am trying to create a symmetry out of a midplane and a set and all i ever get is zeros, also when i try to create a datum definition it does not show...
05-23-2011, 08:17 PM -
by TexasrussianIn PC-Dmis, True Position algorithm takes the centroids of the hits of each side of the feature, finds center point and then reports that point’s distance...
06-28-2010, 01:47 PM -
by LepageHow is it possible to get up to a 0.0717mm difference in symmetry results with the exact same probe and same part program (part was not moved between...
10-10-2011, 06:08 PM -
