circularity will not report correctly
  • circularity will not report correctly
    On 4.2 when using a program that requires the part to be flipped over
    and using an equate alignment , the report for roundness of any circle on the 1st side only comes out looking more like a distance than roundness ,
    any clues to what is happening? I have tried reporting it as the program runs , but that doesn"t work either.
    PH10MQ------ TP200
    CHAMELEON 15-30-10
    PCDMIS 2010
    Are you trying to do circularity or concentricity?
      circularity
      PH10MQ------ TP200
      CHAMELEON 15-30-10
      PCDMIS 2010
        Originally posted by Allen Long View Post
        circularity
        If you report the form of the diameter right after you measure it, it doesnt come out right? Flipping the part should have no effect.
          Can you post some code?
            basic program consistsb of a round aircraft engine part taking hits on a surface
            to create a plane then hits on a id or od to and then hits on a bolt hole to use as timing to miss other features then create an alignment run a few id's and od's go to manual then flip the part and use the same datums if possible and make an equate alignment which still works great .my only problem is all id's and od's from the first side will not report circularity correctly.
            PH10MQ------ TP200
            CHAMELEON 15-30-10
            PCDMIS 2010
              Do them before the equate.
                What cmmguy says is true. Have you tried this?
                You have not posted code. If you could lease post a copy/paste of your code so that we can look at it? Or use the # sign and place your code within the 2 "code" brackets to retain the correct spacing of your code.
                • HVLee
                  Basic knowledge for circularity
                  by HVLee
                  Hello, I researched and found few questions about circularity of a circle but most of the Q&A are not for beginner like me so I decided to post this...
                  10-22-2014, 12:48 PM
                • acgarcia
                  Calling out Circularity
                  by acgarcia
                  Good Morning:
                  I have a circle that is 5.000" in diameter ±0.001". There is no circularity callout but my boss would like to see...
                  01-20-2016, 09:24 AM
                • AuRules
                  Form ID roundness
                  by AuRules
                  When checking roundness of a ID and the print does not specify a roundness callout, is it safe to assume that the diameter controls the roundness. This...
                  01-29-2013, 02:17 PM
                • AuRules
                  Roundness
                  by AuRules
                  Having a issue on roundness. When we machine our propeller sockets on our hubs. Were showing out of roundness condition. But the key is that were only...
                  08-14-2008, 10:23 AM
                • Jeff Andresen
                  Reporting roundness
                  by Jeff Andresen
                  I have ver. 3.7 (2) , I measure 4 simple holes. I add roundness or form to the program, save it and close the program. When I re-open the program the...
                  12-18-2007, 09:06 AM
