Any way to make it key in automatically when using variables for the measured? Keeps popping up when I used variables.
keyin dimensions
Isnt the whole premise of keyed in dimensions to prompt the operator for them?? like from a caliper or mic.
Originally posted by cmmguy View PostIsnt the whole premise of keyed in dimensions to prompt the operator for them?? like from a caliper or mic.
http://i58.photobucket.com/albums/g2...theobvious.jpg<internet bumper sticker goes here>
There is a way. Dwade has posted about it. I use the generic feature method that Matt mentioned.Last edited by John Kingston; 06-19-2007, 02:58 PM.When in doubt, post code. A second set of eyes might see something you missed.
I"m using v4.1 not sure what he was using. I have mine marked etc, won't work, but i'll try your generic feature.I used to be high on life but I built up a tolerance.
by Stephen1055Is it possible to use a variable or equation for the measured output in a key in dimension?
I have a calculated dimension that I would...-
04-17-2014, 03:54 PM -
by hitalovI have a dimension that it is imposible to get directly, i have to calculate the dimension measuring other fixtures, but in the report i want to show...
12-03-2014, 01:28 PM -
by Stephen1055I have a program with a couple of Key-In dimesnions using calculated variables (change with each part) for the Measured.
Each time I run...-
12-11-2014, 03:19 PM -
by ThomasNZI need to create report label that is capable of comparing two dimensions, for example, dimA = dimB +- 0.1mm. If some one can help get me started on the...
07-27-2011, 04:04 PM -
by db1561I am running 2013 ver:Rel, And when I go to create dimensions it can take up to 5 minutes before its done? has anybody else having this issue? any...
04-08-2014, 03:19 PM -
