Ok i'm getting annoyed by this v4.1 construction. I'm trying to get a mid-line between two lines and it's making it perpendicular to them instead.
v4.1 constructing a line
Mid-lines
Originally posted by scanner View PostThe vectors of the two lines you are using to create the mid-line need to have the same vector, if they are opposite each other you get a perp. line. HTH
This was a huge issue for me because of the way we pick up our fixtures to inspect electrodes.
Your mid-lines will come out correct if the vectors of the lines are the same in 4.1, or 4.0.
Timsigpic
This there a way to make the constructed lines longer?
!'m intersecting 2 planes and the constructed lines are minute, can just barely see them....-
01-23-2020, 02:05 PM -
by rh_24571Running PC DMIS 2016 with latest update. I have created two lines from a diameter to individual points. After this I have tried to create a mid line between...
11-22-2017, 10:49 AM -
by WolfManHaving an issue constructing a Cir with 2 Tang lines. Any suggestions?
It creates a Cir, but it is not Tangent to any lines, well maybe just...-
07-18-2017, 09:51 AM -
by dwadeJust wondering how many of you use auto-feature lines in alignments. I've known for some time that I shouldn't use them in alignments and was working...
01-15-2009, 07:56 AM -
by Tho35How to measure the Perpendicularity DIM for this case, I measured these two lines and contruct Perpendicularity Dimension from these two lines but PC...
04-27-2007, 05:55 PM -
