I've dabbled in there before and can't seem to get to that toolbar. It only goes as far as view/report window. So it will let me change the "report window" icon, but nothing paste that. I thought it may be in the actual editing of the report.
My apologies for being facetious. You are correct, there's no way to edit the REPORTING toolbar in that window.
however, in the "Reporting Toolbar" help it says the following (SHIFT+ DRAG each menu item to customize and zap all the default ones): reporting toolbar.jpg
This still doesn't let me customize the look of the icon. To clarify further, I made a new template and added it to the toolbar as described above. But the icon is the same as the other template I have in there. If I hover over it I can see that the name is different, but besides that and placement, there is nothing that distinguishes it from the other type of report. It's not a huge deal as there is only me the programmer and 1 operator. it'll be easy enough to explain. Just trying to make the icon different. For instance I think there is a preset report that I took out of there that says text and CAD OOT. That report had a different icon. So it must be able to be done somehow. Thanks for your efforts.
Hey guy's, using version 4.1 in the report window, now for some reason evertime we run a program the window shows a blank report, we have to pick the...
On my report window after program has ran, I lost all the tabs across the top; does anyone know how to get this back? I lost these right after I was moving...
This started last Friday. My report window is open, and is normal size. But all I see is a small white rectangle about 3x4mm. Is this the report? What...
