pretty basic question: How do you measure a simple diameter without writing a program? I can beep 4 points around the circle and see they've been accepted in the lower right hand box, but I can't seem to get the diameter to calculate? Thank you.
measure diameter without writing program
-Take 4 manual hits..press OK on jogbox
-Click into the code for the feature you just created and hit F9
-Change number of hits to whatever you want and click OK..click YES that you want the hits to equally spaced
-Click into code above the feature and INSERT/DCC Mode
-With probe still physically in the bore, put curser at top of code and then hit CTRL+U
When using a DCC CMM, you'll get far more accurate results with the machine probing instead of the operator because its impossible for operator to make it touch at the same touch speed that the probe was calibrated at
- Likes 1
The "correct" way would probably be to manually measure a cylinder, primary align to it (lets say in Z), set the origin in it for X, Y, repeat the cylinder measurement and alignment in DCC and then measure the diameter either as a circle or cylinder (in DCC).
Could be nice with a plane or something to use as origin in Z, for depth control.
But who got time for this...PC-DMIS CAD++ 2o22.2 SP2
- Likes 1
by MM4EVERI am curious who can give me a clever way solve this problem. Preferably with as little code as possible.
I remember using loops and...-
02-13-2008, 03:53 PM -
by b.cailleeuwHello,
What is the usual way to measure a diameter with 8 measuring points and with the same measuring points PC-dmis must give me the...-
06-27-2008, 12:06 PM -
by DAN_MI have a bushing with an annoying lip on both sides & I want to measure a diameter approximately half way down in the Z Axis. No my company won't...
11-21-2016, 04:05 PM -
by mrollings53I opened an old program created in April 2019 that managed to screw up something. The program had the point size diameter set to .005". I changed...
04-14-2022, 04:30 PM -
Hello All,
I have a kidney shaped hole that has a radius callout that I can't figure how to measure. (See below)
The blue circle...-
06-09-2020, 11:59 AM -
