need help loop and reports part in report per loop
  • need help loop and reports part in report per loop
    i created this loop program to run either 1 or 6 parts depending on how many they load into the machine in fixture they input 1 thru 6 in an operator input then i use that to see how many loops i need to run. i am having trouble with the report and trying how to show which part in the report is part 1 or part 6. In the report i want to have it report a comment/rept that says at the start Part 1 then when starts next loop i would like it to say part 2 in the report so operator known's what part the inspection reports is for depending on how many parts they decide to run. any help would be greatly appricatied.
    ALIGNMENT/END
    MODE/MANUAL
    OPTIONPROBE/MAXFORCE=0.096,LOWFORCE=0.02,UPPERFORCE=0.072,TRIG GERFORCE=0.06,
    PROBEACCURACY=0.1,POSACCURACY=0.1,#RETURNDATA=7,
    RETURNSPEED=2,SCANPNTDENSITY=4,
    SCANACCELERATION=10,SCANOFFSETFORCE=0.12,
    PROBINGMODE=DFL,MANFINEPROBING=NO
    MOVESPEED/ 300*0.9
    FORMAT/TEXT,OPTIONS, ,HEADINGS,SYMBOLS, ;MEAS,NOM,TOL,DEV,OUTTOL, ,
    LOADPROBE/P5_0PT7X45
    TOUCHSPEED/ 1.8
    WORKPLANE/ZPLUS
    PREHIT/0.1
    RETRACT/0.1
    CHECK/0.2,1
    DISPLAYPRECISION/4
    COMMENT/REPT,
    13-17 GLOBAL
    MO =COMMENT/INPUT,NO,FULL SCREEN=NO,
    'Please Input MO:'
    SERNUM =COMMENT/INPUT,NO,FULL SCREEN=NO,
    'Please Input Serial #'
    INI =COMMENT/INPUT,NO,FULL SCREEN=NO,
    'Please Input Operator Initials:'
    $$ NO,
    CMTJUMP =LABEL/
    $$ NO,
    LOOP =COMMENT/INPUT,NO,FULL SCREEN=YES,
    ENTER NUMBER OF TAB'S PLACED IN FIXTURE
    MUST BE LOAD LEFT TO RIGHT
    ENTER NUMBER 1-6 :
    COMMENT/REPT,
    "MO:" + MO.INPUT +" PART:" + SERNUM.INPUT + " Operator:" + LOOP.INPUT
    $$ NO,
    IF_GOTO/LOOP.INPUT>6,GOTO = CMTJUMP
    $$ NO,
    COMMENT/OPER,NO,FULL SCREEN=YES,AUTO-CONTINUE=NO,
    Please load the part onto T12-864 Fixture be sure
    the part is centered on the fixture. Load the
    T12-864 fixture into the T12-730 small vise.
    Parts need to be loaded in order 1 thru 6
    $$ NO,
    Move probe in Z to the center of the flange thickness.
    Then Center over White Dot on the fixture
    **** DCC MODE STARTS HERE ****
    $$ NO,
    $$ NO,
    MODE/DCC
    $$ NO,
    READ_PNT =FEAT/POINT,CARTESIAN
    THEO/<0,0,-0.1085>,<0,0,1>
    ACTL/<0.9346,-0.6487,0.2223>,<0,0,1>
    READPOINT/
    $$ NO,
    $$ NO,
    A1_TEMP =ALIGNMENT/START,RECALL:STARTUP,LIST=YES
    ALIGNMENT/TRANS,XAXIS,READ_PNT
    ALIGNMENT/TRANS,YAXIS,READ_PNT
    ALIGNMENT/TRANS,ZAXIS,READ_PNT
    ALIGNMENT/TRANS_OFFSET,ZAXIS,0.1085
    ALIGNMENT/END
    $$ NO,
    V1 =LOOP/START,ID=YES,NUMBER=LOOP.INPUT+",START=1,SKIP=,
    OFFSET:XAXIS=2.547,YAXIS=0,ZAXIS=0,ANGLE=0
    $$ NO,
    $$ NO,
    PREHIT/0.1
    RETRACT/0.1
    $$ NO,
    CIR_1 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR
    THEO/<0,0,-0.1085>,<0,0,1>,0.63
    ACTL/<0,0,-0.1085>,<0,0,1>,0.63
    TARG/<0,0,-0.1085>,<0,0,1>
    START ANG=340,END ANG=200
    ANGLE VEC=<1,0,0>
    DIRECTION=CW
    SHOW FEATURE PARAMETERS=NO
    SHOW CONTACT PARAMETERS=YES
    NUMHITS=3,DEPTH=0,PITCH=0
    SAMPLE METHOD=SAMPLE_HITS
    SAMPLE HITS=0,SPACER=0
    AVOIDANCE MOVE=BOTH,DISTANCE=0
    SHOW HITS=NO
    $$ NO,
    A1 =ALIGNMENT/START,RECALL:A1_TEMP,LIST=YES
    ALIGNMENT/TRANS,XAXIS,CIR_1
    ALIGNMENT/TRANS,YAXIS,CIR_1
    ALIGNMENT/END
    MOVE/INCREMENT,<0,0,0.4>
    $$ NO,
    MOVE/INCREMENT,<0,-0.5,0.1>
    $$ NO,
    PNT_A1 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
    THEO/<0.966,-0.4201,0>,<0,0,1>
    ACTL/<0.966,-0.4201,0>,<0,0,1>
    TARG/<0.966,-0.4201,0>,<0,0,1>
    SNAP=NO
    AVOIDANCE MOVE=NO,DISTANCE=0
    SHOW HITS=NO
    $$ NO,
    PNT_A2 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
    THEO/<0.9346,-0.6487,0>,<0,0,1>
    ACTL/<0.9346,-0.6487,0>,<0,0,1>
    TARG/<0.9346,-0.6487,0>,<0,0,1>
    SNAP=NO
    SHOW HITS=NO
    $$ NO,
    PNT_A3 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
    THEO/<0.7394,-0.5342,0>,<0,0,1>
    ACTL/<0.7394,-0.5342,0>,<0,0,1>
    TARG/<0.7394,-0.5342,0>,<0,0,1>
    SNAP=NO
    SHOW HITS=NO
    $$ NO,
    PNT_A4 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
    THEO/<0.5559,-0.6801,0>,<0,0,1>
    ACTL/<0.5559,-0.6801,0>,<0,0,1>
    TARG/<0.5559,-0.6801,0>,<0,0,1>
    SNAP=NO
    SHOW HITS=NO
    $$ NO,
    PNT_A5 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
    THEO/<0.5348,-0.4311,0>,<0,0,1>
    ACTL/<0.5348,-0.4311,0>,<0,0,1>
    TARG/<0.5348,-0.4311,0>,<0,0,1>
    SNAP=NO
    SHOW HITS=NO
    $$ NO,
    PNT_A6 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
    THEO/<0.2439,-0.552,0>,<0,0,1>
    ACTL/<0.2439,-0.552,0>,<0,0,1>
    TARG/<0.2439,-0.552,0>,<0,0,1>
    SNAP=NO
    SHOW HITS=NO
    $$ NO,
    PNT_A7 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
    THEO/<0.0444,-0.6938,0>,<0,0,1>
    ACTL/<0.0444,-0.6938,0>,<0,0,1>
    TARG/<0.0444,-0.6938,0>,<0,0,1>
    SNAP=NO
    SHOW HITS=NO
    $$ NO,
    PNT_A8 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
    THEO/<0.0221,-0.4162,0>,<0,0,1>
    ACTL/<0.0221,-0.4162,0>,<0,0,1>
    TARG/<0.0221,-0.4162,0>,<0,0,1>
    SNAP=NO
    SHOW HITS=NO
    $$ NO,
    PNT_A9 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
    THEO/<-0.2703,-0.5422,0>,<0,0,1>
    ACTL/<-0.2703,-0.5422,0>,<0,0,1>
    TARG/<-0.2703,-0.5422,0>,<0,0,1>
    SNAP=NO
    SHOW HITS=NO
    $$ NO,
    REF FOR MACHINEST TO HELP IF PART IS OUT OR LOADED INCORRECTLY?
    $$ NO,
    DATDEF/A,FEATURES=PLN_DATUM_A,,
    $$ NO,
    $$ NO,
    FCFFLAT4 =GEOMETRIC_TOLERANCE/STANDARD=ASME Y14.5,SHOWEXPANDED=YES,
    UNITS=IN,OUTPUT=BOTH,ARROWDENSITY=100,
    SEGMENT_1,FLATNESS,0.0025,TOL_ZONE_MATH=DEFAULT,
    TEXT=OFF,CADGRAPH=OFF,REPORTGRAPH=OFF,MULT=10,
    MEASURED:
    PLN_0.079:0.0000,
    ADD
    FEATURES/PLN_0.079,,
    $$ NO,
    FCFPARL1 =GEOMETRIC_TOLERANCE/STANDARD=ASME Y14.5,SHOWEXPANDED=YES,
    DATUM_MATH=DEFAULT,
    SEGMENT_1,PARALLELISM,PLANAR,0.003,__,A,<dat>,
    MEASURED:
    PLN_0.079:0.0000,
    $$ NO,
    $$ NO,
    FCFFLAT3 =GEOMETRIC_TOLERANCE/STANDARD=ASME Y14.5,SHOWEXPANDED=YES,
    MEASURED:
    PLN_0.138:0.0000,
    ADD
    FEATURES/PLN_0.138,,
    $$ NO,
    FCFPARL2 =GEOMETRIC_TOLERANCE/STANDARD=ASME Y14.5,SHOWEXPANDED=YES,
    DATUM_MATH=DEFAULT,
    MEASURED:
    PLN_0.138:0.0000,
    $$ NO,
    COMMENT/REPT,
    REF ANGLE (45.0° ± 0.5)
    $$ NO,
    DIM ANGL6= 3D ANGLE FROM PLANE PLN_45.3673° TO PLANE PLN_DATUM_A ,$
    A 45.3673 45.0000 0.5000 0.5000 0.3673 0.0000 -------#-
    $$ NO,
    FORMFEED/
    $$ NO,
    LOOP/END
    $$ NO,
    $$ NO,
    Program Edits:
    ASSIGN/FILE_NAME="Q:\CMM Reports\NorthEast Laser\318536-02\OP10_6PL\"+LOOP.INPUT+" "+SERNUM.INPUT+" "+LOOP.INPUT+".PDF"
    PRINT/REPORT,EXEC MODE=END,$
    TO_FILE=ON,AUTO=5,AUTO OPEN=OFF,$
    TO_PRINTER=ON,COPIES=1,$
    TO_EXCEL=OFF,$
    $$ NO,
    $$ NO,
    $$ NO,
    $$ NO,
    FORMFEED/
    $$ NO,
    LOOP/END
    $$ NO,
    $$ NO,
    Program Edits:
    TO_EXCEL=OFF,$
    I figured it out
      Originally posted by williambutts35 View Post
      I figured it out
      What was your solution?
      • williambutts35
        williambutts35 commented
        Put a counter in before the loop and then assigned it to = 0 then made it in the loop coutner+1 and then i put that in a comment report and put the part#+counter it works good
      -Your comment is before the loop start.
      -I would advise to not use the word "LOOP" in your feature ID's for comments or assignments as it's active syntax (I suggest QTY)
      -Instead of using IF_GOTO, I prefer to use IF command and prompt operator that they messed up... that way they learn (eventually). Also the IF_GOTO will produce errors if someone inputs a non-number, or a value that isn't a whole number (like 1.4) I recommend some syntax like below to mitigate all input errors from fubar-ing your routine.
      -If you move your report comment into the loop, and reference loop id (V1) instead of LOOP.INPUT, it would produce the variable number in the comments.
      Red= Remove
      Green = Replace
      $$ NO,
      CMTJUMP =LABEL/
      $$ NO,
      LOOP QTY=COMMENT/INPUT,NO,FULL SCREEN=YES,
      ENTER NUMBER 1-6 :
      COMMENT/REPT,
      $$ NO,
      IF/QTY.INPUT-INT(QTY.INPUT)<>0 OR !(QTY.INPUT>=1 AND QTY.INPUT<=6)
      Invalid input! Please input
      a value between 1 and 6.
      GOTO/CMTJUMP
      END_IF/
      $$ NO,
      $$ NO,
      $$ NO,
      $$ NO,
      $$ NO,
      MODE/DCC
      $$ NO,
      READPOINT/
      $$ NO,
      $$ NO,
      ALIGNMENT/END
      $$ NO,
      V1 =LOOP/START,ID=YES,NUMBER=LOOP QTY.INPUT+",START=1,SKIP=,
      COMMENT/REPT,
      LOOP.INPUT V1
      $$ NO,
      $$ NO,
      PREHIT/0.1
      RETRACT/0.1
      $$ NO,
      • williambutts35
        Some how where says operator it changed fro ini.input to loop.input its not suppose to say loop there i already fixed that.
      ALIGNMENT/END
      MODE/MANUAL
      MOVESPEED/ 300*0.9
      TOUCHSPEED/ 1.8
      WORKPLANE/ZPLUS
      PREHIT/0.1
      RETRACT/0.1
      CHECK/0.2,1
      DISPLAYPRECISION/4
      COMMENT/REPT,
      13-17 GLOBAL
      'Please Input MO:'
      $$ NO,
      CMTJUMP =LABEL/
      $$ NO,
      ENTER NUMBER 1-6 :
      COMMENT/REPT,
      "MO:" + MO.INPUT +" PART :" + SERNUM.INPUT + " Operator:" + INI.INPUT
      $$ NO,
      $$ NO,
      $$ NO,
      $$ NO,
      $$ NO,
      MODE/DCC
      $$ NO,
      ACTL/<2.547,0,0>,<0,0,1>
      READPOINT/
      $$ NO,
      $$ NO,
      ALIGNMENT/END
      $$ NO,
      ASSIGN/COUTER=0
      $$ NO,
      LOOP1 =LOOP/START,ID=YES,NUMBER=LOOP.INPUT+",START=1,SKIP=,
      $$ NO,
      ASSIGN/COUNTER=COUNTER+1
      $$ NO,
      PROGRAM ****************** MISSING TO LONG*********************
      WORKPLANE/ZPLUS
      $$ NO,
      $$$$$$$$$$$$$$$$$$$$$$$ START OF REPORT $$$$$$$$$$$$$$$$$$$$$$$
      COMMENT/REPT,
      "PART #" + COUNTER
      LOOP/END
      $$ NO,
      $$ NO,
      Program Edits:
      W. BUTTS REWROTE 12012022
      TO_PRINTER=OFF,COPIES=1,$
      TO_EXCEL=OFF,$
      PREVIOUS_RUNS=DELETE_INSTANCES​
      • louisd
        louisd commented
        okay i guess you aren't open to improvement?
        report your loop count "LOOP1" or "COUNTER" in a report comment between loop/start and loop/end and you should be set
      Im open to improvements what u mean im just messing with this i dont need it. But im still learning.
        I did Try what your talking about in my program with the
        GOTO/CMTJUMP
        END_IF/
        thank you but the other parts had changed when i had saved it and put in loop.input when it was ini.input
        still learning some basic's on computer programing part's what i can use but works both ways your way is better cause if i enter 0 it still runs 1 loop. thanks for help
          IF/QTY.INPUT(QTY.INPUT)<>0 OR!(QTY.INPUT>=1 AND QTY.INPUT<=6)
          Invalid input! Please Input a value Between 1 and 6.
          GOTO/CMTJUMP
          END_IF/
          HEY LOUIS D WHAT IS THE INT AFTER THE INPUT FOR I TOOK IT OUT TO GET IT TO WORK.
          GOTO/CMTJUMP
          END_IF/
          • louisd
            louisd commented
            INT = INTEGER, a whole number. It will push out any decimal values and any other characters or symbols as invalid.
            The comment input must be a whole number (either 1,2,3,4,5 or 6) in order to pass with at YES/1 outcome. If you add a letter or a 1.4, or a symbol, the error comment will appear (in your flattening of the two lines of the comment, the fullscreen message will not wrap text, and you will lose visibility of a bunch of the message). Then, you will need to click OK to be re-prompted to input the correct value.
            The "if" statement I provided in its entirety, works flawlessly on my routines I've got running on four machines and on a 24/7 operation... Including the first portion of my or statement you removed: IF/ QTY.INPUT-INT(QTY.INPUT)<>0
          so i took it out but i will add it back in thanks this was a big help. I am programming for three machines we run in operator mode just started running this software again been 10 years since i used it and im so slowly getting back to how this one works.
            Another question is there a way to make the counter reset every time you execute? If i dont close the program and reopen it it does 1 thru 6 and when i excute without closing the program it countiunes the counter for next parts at 7-12.
            • SABarber
              SABarber commented
              ASSIGN/COUNTER=1
              Before the loop.
            • SABarber
              SABarber commented
              Looking at the code use 0 instead of 1
            • louisd
              louisd commented
              The only way in which your counter will go over 6 is if you are using multiple loops.
              Place the ASSIGN/COUNTER=0 after first loop and immediately before the second loop.
