I am tasked with obtaining the Minimum and Maximum distance of points from a datum or X origin (they are the same feature). I was able to accomplish this using ASSIGN and ARRAY with the 64 planes. The customer has need of the Min/Max data from the 256 points that the constructed planes are comprised of. The same ASSIGN functions I was using will not accommodate the amount of features that I need data from. There's some limit on how many features you can have on a line or to assign to.
Below is the variable I was using for the plane features. Is there help I can get to adapt this for the Min/Max distance for 128 individual points? I need to know the distance the plane is from origin on the X Axis at any given point and not just the plane. Thank you for the help!
